low boost d1sc
Old Dec 30, 2014 | 12:55 PM
crispytoast's Avatar
Default low boost d1sc
I currently have a 3.4 head unit pulley and a 7.5 crank pulley which should put my blower spinning about 66000 rpm at 6700 engine rpm. I have verified that I have no leaks and no belt slip but I am only making 11# of boost. Right now I have a big red valve is it possible that the valve needs adjustment? I am at about 5000 ft elevation right now and I know that will have some effect but there are other d1 cars here that make 18 #. Another thing that might have something to do with it is the 6 degrees of overlap on my cam?
Background: ls1 with ls6 heads, 102 intake, 228/232 on 112
Old Dec 30, 2014 | 12:58 PM
2002kirk's Avatar
The red valve probably needs to be adjusted. That was an issue on my friends corvette with his set up. And the elevation is against you. And the cam, I can't give you any help on that. Idk but that much over lap isn't much
Old Dec 30, 2014 | 01:00 PM
Which way should the valve be adjusted and how much?
Old Dec 30, 2014 | 01:02 PM
2002kirk's Avatar
How to adjust it I'm insure of. The only reason I could help him figure it out. Is because I heard it blowing off boost. So I would say it needed to be tightened.
Old Jan 1, 2015 | 07:32 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Between your elevation and your overlap, I'd say you don't have any boost leaks. At 5000 ft you're not going to make a lot of boost with a D-1SC. The only way someone there is making 18 psi with a D-1SC is with clogged cats, or on a very small displacement engine. A D-1SC at 900 ft on an LS1 with a cam and headers is doing well to make 16 psi. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 1, 2015 | 10:12 AM
Guess i need to start saving my pennies for an f1
Old Jan 1, 2015 | 10:15 AM
LS1Tech Sponsor
__________________
Old Jan 1, 2015 | 09:12 PM
Rise of the Phoenix's Avatar
What kind of power does the car make?
Old Jan 1, 2015 | 10:15 PM
