Will this turbo work? New edge mustang
Starting from a base Borg Warner S400 we have fitted this with a 80mm extended tip billet high flow compressor wheel
Compressor cover fresh polish Compact S410 Compressor cover (small vband out)
Wheel assembly balanced. severe duty bearings + 360 thrust
Compressor wheel - 80mm inducer / 113mm exducer / 117.55 Exended tip
Turbine wheel - 77.5mm/87mm
Compressor inlet - 5" hose Ported Shroud
Compressor outlet - 2.5" v-band
Turbine Inlet - Divided T4 1.10 A/R
Turbine outlet for 4"v-band
Will it work better with an lq4 or 5.3? and anybody know of a turbo kit for the new edge with ls swap? I know on3 makes a kit for fox body but not 99-04 stangs with ls swap?
Jack
