800hp with a 044 pump?
Old Jan 16, 2015 | 11:59 AM
gsxrred1000's Avatar
Default 800hp with a 044 pump?
Has anyone cracked the 800 rwhp mark with a single Bosch 044 pump. Trying to figure out my fuel system and only wanna run one fuel pump. Not really digging the price of the top name fuel pumps. It has to be inline fuel pump due to fuel cell I'm running. Would twin 255's be better than trying to squeeze 800hp threw a 044? Pretty sure I have -8 or -10 feed line now but will have to run a -6 return. Billet fuel rails with aero motive fpr. Running a 5.3l with billet s476r.
Old Jan 16, 2015 | 12:15 PM
2muchboostNY's Avatar
From previous experience in using these on 2JZ setups, I am almost certain the 800rwhp make is above the capabilities of the pump. I know 800rwhp has been exceeded using 2 of these and gotten to the 900rwhp mark. -8 should be fine for your goals.
Here is an article discussing some pumps including 044's:
http://realstreetperformance.com/Fue...ison-Test.html
What fuel will you be using? Something else to keep in mind is the fuel consumption for different fuels.
Old Jan 16, 2015 | 12:47 PM
JoeNova's Avatar
Restricted User
Denmah made 720 to the wheels with a single 044 and -6 AN feed line and 58 PSI base pressure. I believe he turned it up quite a bit more at the track and was probably close to 800 whp. This is the highest I've heard of on a single 044.
Maybe he will chime in with more info. I have no idea if it was knockoff or true 044. I never even considered the 044 for a 700 whp build until I seen his dyno and track numbers.
Old Jan 16, 2015 | 01:07 PM
stevieturbo's Avatar
Only in the US do people seem to get those sort of numbers from an 044.
Everywhere else in the world they're a genuine 650 flywheel HP in a typical fuel injected turbo application. Some may get slightly more, but it is really beyond its safe limit.
But no way will it support 800hp unless perhaps you fired 21v at it instead of 12-14v.
You could do a pair of inline Walbros, or a pair of cheaper Bosch pumps, 909's or something.
Old Jan 16, 2015 | 01:13 PM
chuntington101's Avatar
Steve, do you have a bit of déjà vu? lol sure this was discussed today on pistonheads!
Old Jan 16, 2015 | 04:55 PM
denmah's Avatar
Moderator
i was definately on the edge of the pump, at 700whp thru an automatic (80e)
Old Jan 16, 2015 | 04:56 PM
denmah's Avatar
Moderator
i would say it might be able to get done, but dont expect it, or expect it to be reliable.
depends on converter and loss, youll definately hit it with a stickshift car.
denmah's Avatar
Moderator
twin 400s in a tank is very economical at under 200 dollars for Y fitting and twin pumps etc
Old Jan 16, 2015 | 06:13 PM
Ok. So I guess one 044 won't cut it. I will be running 93 oct. pump gas and 50/50 methanol mix in water inj. What is max hp on 2 - 255 pumps running together all the time? Won't be on high boost a whole lot but figure ill be at around 600hp mainly on street with a little extra(up to 800) at the track every now and than.
Old Jan 16, 2015 | 06:22 PM
Here's the specs stock 5.3l with martins new 4.8/5.3 stage 2 turbo cam. 660 lift springs, retainers, seats etc. stock heads. Chinese head studs. Ls1 intake. Built Th400 with 3800 stall converter. 3.23 rear gears in built 10bolt. Hope it holds lol. S476r turbo with billet wheel and 1.10 ar. 2.5 crossover with 4" dump pipe.
Old Jan 16, 2015 | 08:41 PM
yenkomike's Avatar
that is very close to the combo denmah ran . he ran 17# boost with a single 044 and ran 9.60s at 145 mph
Old Jan 16, 2015 | 09:28 PM
denmah's Avatar
Moderator
do twin 400lph pumps
we have actually done 700whp with a single 400 thru an automatic!
Old Jan 17, 2015 | 03:58 AM
I have a fuel cell and those 400lph pumps are in tank pumps. What about those speedmaster pumps on eBay ? Look like a a1000 but say good for 1000lbs hour.
http://www.ebay.com/itm/171429033554
Old Jan 17, 2015 | 10:39 AM
Forcefed86's Avatar
Were you running 80lb injectors? What did the DC on the injectors look like on that setup w/ 58psi base?
Starting out at 58psi base makes the pump work pretty hard before boost is even introduced. If you the lower base pressure to 40 (assuming you have enough injector) you can get alot more flow from the pump. You can't compare 600hp made on a 4/6 cyls to 600hp made on a 5.3. The 5.3 will do it at MUCH less boost so the pump isn't working as hard.
Your 800WHP goal sounds a bit lofty with your combo. I don't think you'll make anywhere near that on a cammed SBE with your choice of heads, converter/trans,turbo, and pump gas.
I'd want 85gph worth of pump to hit 800WHP. IMO it would take 25+lbs to hit 800whp with your setup. So you need a pump that can put out 85gph at 68-70 psi.
Multiple 255HP's are still your best bet for cheap power with inline pumps. $91 each with AN fittings. A single 255HP pump puts out about 58gph at 60psi at 13.5v. (116gph for 2)
This setup was around $212 to make with cheap china AN fittings and pushlock hose.
Using 2 harbor freight 3-way fittings you could setup a triple 255hp pump that will put out almost 175gph 60psi for about $300
Here are most popular fuel pumps with noise and flow tests...
http://radiumauto.com/media/techarti...l-Pump-Test-87
Old Jan 17, 2015 | 11:30 AM
If denmah made 700+ with 80lb injectors and a single 040 with a smaller cam than I'm running why would 800 be to far fetched if i fueled it with enough fuel. This is what im trying to figure out and need help with i dont want the fuel pump or pumps to be my limiting factor. Martin from tick said 800 should be achieved with About 18lbs of boost. I realize there are some limiting factors with my setup. I like the twin setup that is pictured there and the cost is nice.
Old Jan 17, 2015 | 11:38 AM
An 040 is a dedicated in tank pump and flows slightly less than an 044
And an 044 at normal voltages is never supplying 800bhp unless the dyno is sprinkled with fairy dust or something.
The 775 number quoted in the link above is still high, but probably based on dead end flow, and not factoring in that some fuel flow will still return out the FPR.
Old Jan 17, 2015 | 11:50 AM
Sorry I meant 044 in last post
Old Jan 17, 2015 | 11:54 AM
I figured that, but still worth mentioning Bosch also do a dedicated in tank version.
Or just fire the 044 in tank, makes little odds.
Old Jan 17, 2015 | 11:58 AM
Pump gas and water/meth should not be a limiting factoring considering the methanol octane content for detonation.
Old Jan 25, 2015 | 12:58 PM
suicidal racing's Avatar
aem 380 pump should be able to do it..they do 90gph at 70psi and 100gph at 43psi..can be had for 150$
