1700HP TT Glide 9" C6 Z06 Build
#163
not really but i am upgrading what is causing it. the bushings are rubber and weak so these are coming in today to take care of the issue.
https://www.lgmotorsports.com/corvet...l-arm-kit.html
#164
#172
#174
#177
#178
i was sorting out new suspension i had just finished installing. i ran a 8.9 at 163 on progressing up to 10lbs, on the fr8train run i forgot to turn the boost controller on after my burnout so up till the 8th mile i was on 4lbs and once on i was at 15lbs. hence the wierd time slip..
#179
over 40 MPH out the back on only 15 pounds. That car is going to go so fast once you get it sorted out its going to be scary.
Good to see your taking your time and sneaking up on it.
