Which gauges recommended with boost?
Also I am pretty sure that I'll be running a boost leash can I use that as the primary boost gauge? Ill be driving the car on the street probably 90% of the time
Thanks!
You will no if there is a problem. It usually comes after a loud bang.
Boost, fuel level, fuel pressure, oil pressure, temp, and tach. Even then most of it can be shown on whatever ecu you are running.
