aes 390
Old Mar 2, 2015 | 11:33 PM
dmaxvaz's Avatar
Originally Posted by 383camaroz28
Ok aes is out then,
370ci, 390ci (else where), 408ci.
Which should i do ?
Do a 385 like I suggested. Order the crank from callies, rods, and pistons from diamond. Have a shop like baker engineering do the machine work and assembly. Or talk to Tj @ Baker Engineering to put an engine package together for you.
Old Mar 2, 2015 | 11:47 PM
SSZ's Avatar
SSZ
Take this guys advice. Use it. I dont think you will be disappointed.
Old Mar 3, 2015 | 06:21 AM
LS6427's Avatar
Do i get the crank right from callies? I dont see it on there site.
I bought mine direct from callies..............then sent it to AES to do the build.
Ebay is a good place to check....people sometimes sell brand new Callies cranks less than Callies will sell it.
Old Mar 3, 2015 | 06:24 AM
LS6427's Avatar
Ok aes is out then,
Which should i do ?
You want to use an S480 you said?????......you could go very cheap and use a stock crank....forged rods and pistons. Build a 370ci iron engine. Good till 1,000 RWHP with the factory crank.
You don't want too much cubes unless you plan to go with the larger T6 single turbos....
Old Mar 3, 2015 | 07:08 AM
oscs's Avatar
Originally Posted by Meth Sled
I wouldn't bore an LQ block over 4.030", not when you're throwing boost into the equation. Some say the max for N/A build is just .065 over before the cylinder walls start getting weak.
I wouldn't sweat a 4.030 bore size for a second. There are tons of guys running them.
Old Mar 3, 2015 | 07:16 AM
oscs's Avatar
Originally Posted by willizm
Isn't AES the same vendor that requires an oil changer after 2 dyno pulls else it voids the warranty?
Yup! I was going to comment but i decided to keep my mouth shut. That was an interesting read.
Old Mar 3, 2015 | 08:19 AM
383camaroz28's Avatar
Ls6427 its hurons new T6 turbo kit i got with s480 w/racecover. Maybe ill do TSP 408 it came out to 4800
Old Mar 3, 2015 | 08:26 AM
dmaxvaz's Avatar
Too much stroke for lq4 block.
Old Mar 3, 2015 | 12:14 PM
stevieturbo's Avatar
3.825" is a good all rounder, failing that just stick with stock stroke.
Old Mar 3, 2015 | 01:39 PM
LS6427's Avatar
T6....get a 390ci. Make 1,200 RWHP without breaking a sweat. Maybe a 402ci......
Whats your RWHP goals....if its under 1,000 you can do the 370ci and save money bu using a stock crank. You'll make 800-900 with cheap *** LS1 243 heads and LS6 intake with a stock TB.......LOL
I'm thinking of getting the Huron Speed T4 Single Turbo A/C kit..........PT88 mid frame with 4" DP bumper exit pipe. 800-850 RWHP is what I'm after. Ive been told by turbo gurus the PT88 will get me there easily....with my 390ci.
Old Mar 3, 2015 | 10:13 PM
800-850 on street 1000 at track, 370 will prob do
Old Mar 4, 2015 | 12:47 AM
  #32
Kmspeedie's Avatar
take a look at Thompson Motorsports, John from huron works with them as well and can get you a deal onna motor. I love mine from them and it has a 1 year unlimited mileage warrenty... for boosted applications!!
Old Mar 4, 2015 | 06:23 AM
  #33
oscs's Avatar
370 is plenty big.
Old Mar 4, 2015 | 07:40 AM
  #34
What internals did you get TMS crank an rods? How much power?
Old Mar 4, 2015 | 08:46 AM
  #35
Kmspeedie's Avatar
I got their crank and rods and diamond pistons, and main/head studded it, a 416 ls3, so its rated to 1100hp and theyll warrenty up to that.. whats better than that lol.. most companies void warrenty under boosted apps
Old Mar 4, 2015 | 09:51 AM
  #36
oscs's Avatar
Most shops wont give a warrant period!
Old Mar 4, 2015 | 09:54 AM
  #37
They might offer some sort of warranty against defective materials or something.
But in general no performance parts carry a warranty, simply because there are so many variables.
Old Mar 4, 2015 | 10:48 AM
  #38
gsteele's Avatar
What is your understanding of what this warranty entails? No matter what you do to the engine, if it breaks, they will replace it for free within the first year?
Old Mar 4, 2015 | 11:03 AM
  #39
I seen post about kyle replaceing a engine that failed. Nice shop there..
Ill look into TMS 370 or even a lsx block engine
Old Mar 4, 2015 | 11:08 AM
  #40
I also still got my 347 but was told its to small for a s480 1.32ar
