(Burnout vid )69 Camaro SS Turbo 5.3l/lil john stage 3 cam/th400/s476r DYNO RESULTS
#63
Thanks for loading it. Needed to finish off some Bfg ta's That have been on the car for 5 years. Many many burn outs and would actually pull front tire with my old stroker motor. Best tires I ever had. Needless to say I bought a new set of same tires. Lol.
#67
Update 4/26/16 new ptc converter and rebuilt trans.
Was limited to 15psi because of 6psi spring in wastegate. But car is still living and doing well. Made 600 whp at 15psi. Only a gen 3 motor but I wanna push it a little more see what I can get outta 20 psi.
#70
Matt happels dyno day results
Decided to turn it up just a hair more. Lol. Gen 3 5.3l still living after 18 psi pull that made 656whp at 6200rpm. Matt lifted early just cause he knows we were pushing the limits already. Lol pretty happy with results of this car.
#73
Made it to the track last Friday. Couldn't build more than 2psi in 1st gear on 2step at 2800rpm. So I raised 2 step to 3500rpm and 2stepped it in 2nd made 5 psi an bumped it into 1st when I left line. Lol. Was going 1.93 60ft with 2 psi and went to a 1.72 with 5psi. Went a 6.82 at 106 in 1/8th on 12psi. And I turned boost to 17psi but it went a little rich at 10.5afr and only made 15 in 1st ,16 in 2nd and 17 in 3rd. Went 6.9 at 105 in 1/8th and 10.6 at 129 mph in 1/4. Drove car to track and home so I guess it's not to bad. Wanna get a 9. Need to push it more and leave with more boost. Soon swapping in l33 rods and pistons and 799 heads.
#74
Just one more click. Lol
Went back to the track and managed to pull off a 10.1 at 136.6. Kept turning the boost up on the dial a boost and should have went One more Click. Lol. Made 15psi in 1st gear ,16 psi in 2nd and 17psi in 3rd. Got some room for more boost yet. 2 step set at 3400rpm and built 5-6psi on line. Not my 9 sec. Run I've been trying for but felt fast as hell. Than they booted me for no cage or safety gear. Haha.
#79
6.52@110.xx. 5psi on 2step then 15 psi in first gear 16 PSI in second and 17 psi in third. 90 degree intake temperature leaving the line and 115° at Finishline. 12° timing on 17psi. Spraying water meth from 12 psi to Finishline
