Fuel Pressure still dropping
Old May 31, 2004 | 11:19 PM
Ed Blown Vert's Avatar
Default Fuel Pressure still dropping
After the Walbro 340 Intank install. I have 62 psi @ idle and while running. At WOT, it will drop to 50 psi. Injector DC is still about 116%.
How much should FP drop with 5# of boost?
It is better than before, dropped to 35-40 and DC was 146%
Old Jun 1, 2004 | 08:12 AM
BIGBOS's Avatar
Its never good to have it dip, anything around 50 at WOT would be "tolerable"
I think those injectors are maxed
Old Jun 1, 2004 | 10:25 AM
Well I guess 50 psi isn't that bad. I just saw the 12 psi drop and thought damn, still not enough pump.
After posting and reading, I got rid of the 38's for the 42's thinking that would be enough for 500 rwhp.
Would 50's be enough? Or should I just add an inline to get the pressure up?
When will this end!!!
Old Jun 1, 2004 | 10:42 AM
PurEvl's Avatar
I got 600 rwhp with 42's in the car. IT would start dropping at 6k though. I would think 500 shouldnt be a problem with 42's??
Old Jun 1, 2004 | 10:54 AM
What was your Fuel Pressure @ 6K?
Old Jun 1, 2004 | 10:56 AM
kp's Avatar
kp
I have seen over 500 with 42s @ ~50psi of pressure. You did change your filter right
You can do a boost referenced regualtor also to keep the pressure up. Mine drops to ~52 at above 5lbs of boost and above. If you can control your a/f down to 10:1 or so you should be just fine..
Try to tune what you have, BTW there are several '42lb SVO' injectors out there, some on eBay are more like 39s (forget the part number) so be carefull..
Old Jun 1, 2004 | 11:02 AM
Yep, the filter was the first thing I changed when I started having problems.
I'll get it on a dyno and see how it is. If I can get rid of that high rpm lean-out. I should be ok. Then I will pulley up and get my 500 rwhp.
I bought the 42's from SC-MECHAM-WS6. So I am sure they are 42's.
But it was weird that I didn't have to change the IFR.
Old Jun 1, 2004 | 11:27 AM
MECHAM's Avatar
they are 42's...green tops
Old Jun 1, 2004 | 11:29 AM
kp's Avatar
kp
there are several geen top bosche/ford injectors - I have a chart here somewhere of what ford part numbers are what. I'll dig it up..
Old Jun 1, 2004 | 11:37 AM
This is the part number 280 150 558
Old Jun 1, 2004 | 11:52 AM
kp's Avatar
kp
I just cut the ford section out of the chart, there are dozens of bosch injectors that have green tops in the bosche number list. I figured they were all the same until someone brought a car in here with them and I couldnt figure out why the thing was running out of fue and the IFR table didnt make any sense.
I'm not saying anyone here misrepresented anything or what you have isnt 42lb ijectors, just be careful what you buy with these, just because they are green dont automaticaly mean they are 42lb.
Old Jun 1, 2004 | 11:59 AM
Which ones are the correct 42's?
This is the document I found.
http://www.powerpage.dk/produkter/pic/injectors.pdf
Old Jun 1, 2004 | 12:02 PM
kp's Avatar
kp
Thats the same chart I have here..
someone can do the math to convert cc/min to lb/min but here are your injectors in the chart. Without knowing the correct test pressure they are rated at its more or less a guess anyhow.. I'm no injector expert, I just had troubles with a set of green top bosch injectors and when I swapped them out for a set that was pulled out of an SVO box (different p/n on the injector) the IFR fell right in line and the car ran way better even on stock offsets.
Whether or not the others could have been made to work fooling with the IFR and PE I dont know, wasnt my car and I didnt want to spend a lot of time on it..
Old Jun 1, 2004 | 12:20 PM
PurEvl's Avatar
It would drop from 60ish to 54. Now I run a regulator that adds 1 psi per pound of boost and also got 60# injectors. I see 6800 with no issues now
Old Jun 1, 2004 | 12:24 PM
It comes out to 39.8 lb
Old Jun 1, 2004 | 12:28 PM
kp's Avatar
kp
next time I'm at the shop I'll dig up those injectors I pulled out and see what the part number was. Since you really dont know for a fact what pressure that 418CC is or at what pressure it can make 84hp per cylinder its all just a guess. I'm sure if you contacted racetronix or RC they would know what number you have there..
My main point was there are a ot of different bosch injectors out there, I dont know enough about the ones you have to say what they are
Old Jun 1, 2004 | 12:34 PM
True, there are too many variables. But I would hope they would have been larger than my 38's.
Old Jun 1, 2004 | 12:42 PM
kp's Avatar
kp
If you can get your a/f right and PE table changes seem linear on the dyno/wideband then dont worry about it. I bought my injectors used and I just went and looked and I have the same p/n as yours. I seen these injectors make 540rwhp with a blower so I'm not too worried about it..
Old Jun 1, 2004 | 12:57 PM
Thanks, if it works. Its all good.
Old Jun 1, 2004 | 12:58 PM
MECHAM's Avatar
sorry man...i bought them off ebay a long time ago..and they were listed at 42# injectors..Ford Lightnings
