I have a confession to make..
Old Jun 2, 2004 | 12:21 PM
  #61
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
im not saying that it doesnt rob i just said thats what i belive it said in the destructions,and as far as pms no there has been none,ive been keeping to myself on this feasco,the kit well has.............ya know i dont even want to say because i will just get yelled at for starting stuff like i did before,and i wont say either because you will also just find a way to somhow balme it on me and i cant even get a return phone call from you to buy stuff never mind to fix stuff so i will just leave it at that
Old Jun 2, 2004 | 01:19 PM
  #62
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Old Jun 2, 2004 | 01:46 PM
  #63
MIGHTYMOUSE's Avatar
my controller works great! if anyone has any questions on it feel free to pm me or call turbosmart directly to hear it from the horses mouth.. i have been helped by david mariott in particular a great deal in the past.
Old Jun 2, 2004 | 03:19 PM
  #64
Rob Raymer's Avatar
Okay, so I guess you don't need my help then?
02Blue - I can agree with you. That very well may be the difference. Good point.
And I actually agree with MM here. If anyone needs any help with the turbosmart controllers, they should in fact PM MM. His track record with it has proven he knows how to use it correctly. Whereas, I just got lucky.
Thanks!
Old Jun 2, 2004 | 03:48 PM
  #65
RICE ETR's Avatar
Turbo Addict
Personally, I wouldn't want a boost controller that cuts my boost in half when it reaches an overboost limit. That's just retarded. If that's what this controller does, according to MM, then that will keep me from buying one down the road. I'll be content with my HKS controller. :p
The OBS is there for a reason.... to PROTECT your engine in the case of overboosting... break that down... more boost than you want/and/or tuned for/can safely run. If you are overboosting than something is WRONG. Instead of trying to finish the pass and make a decent time, how about you let off and see what the hell is not working correctly.... as in a wastegate line blowing off/melting, etc... or even if user error in that you tried to crank your boost up in the burnout box but went too high not paying attention. Cutting it in half is great.. better yet kill all the boost.. then you stand less of a chance of popping something.
Either way we are beating a dead horse... if you don't like/agree with what THEIR instructions say, call turbosmart and tell THEM they are wrong.
Old Jun 2, 2004 | 04:09 PM
  #66
02BlueFirehawk's Avatar
Not saying OB protection isn't a necessity, but that if I am running 20lbs, hit 22lbs, and it drops me to 10lbs all within a second or two, the motor is going to be dumping A LOT of fuel into the motor with less air until I let off the throttle. Last I heard that wasn't good for a motor either. I'm no expert and I think really only the turbosmart guys should be considered an expert on why their EBC does what it does. If I wanted help with their unit, I'd probably contact them directly first.
Agree this is really just pointless. Fix your damn EBC dave and race that heap again this weekend!!
Old Jun 2, 2004 | 04:39 PM
  #67
noted! and it was never broken nothing to fix, but it was adjusted soon as i noticed.
p.s. my dfi fuels via boost so it would trim accordingly
Old Jun 2, 2004 | 04:56 PM
  #68
MECHAM's Avatar
so when are you going to the track next for some 15psi?
Old Jun 2, 2004 | 05:02 PM
  #69
Yeah I meant adjust your **** and race!
Regarding boost regulated fuel, good point. I guess worst case would be a hickup of fuel.
Either way, I'd like to see you and Raymer just get it over with and race.
Old Jun 2, 2004 | 05:16 PM
  #70
no i dont need help because you cant help me with whats wrong with it
Old Jun 2, 2004 | 06:08 PM
  #71
cablebandit's Avatar
The DFI sounds cool Dave. I am going to keep plugging with edit since I already have it. Rob got good results so I will try to replicate those. Can the turbosmart function ok with twins?
Old Jun 2, 2004 | 06:29 PM
  #72
sure i dont see why it wouldnt be able to.. the cotroller doesnt know where its getting the signal from.. be it one or two turbo's.
well jerry as you know the stock computer CAN certainly support hp in controlled conditions.. but it will quickly get tricky when you try to get 600rwhp+ capable through weather changes.
Old Jun 2, 2004 | 09:01 PM
  #73
Rob Raymer's Avatar
Sorry, I have to once again disagree. I ran over 700rwhp with the stock PCM and stock engine from November until March. That's basically from below Zero to 80+ degrees. (how's that for weather changes?)
Bottom line: If it's tuned right, it's not a problem.
Transdamit - sorry I couldn't help.
02Blue - No race for me and MM. It wouldn't be fair. I have a shop and car mod tax write-offs. Even though his car is MUCH MORE MODIFIED THAN MINE, it still wouldn't be fair .
Old Jun 2, 2004 | 11:22 PM
  #74
rons 00z's Avatar
sorry off topic
Old Jun 3, 2004 | 12:45 AM
  #75
Jammer's Avatar
Racin' or not, MM, come out to NS... remember Friday night is Street Car Chaos at the track! According to APE, I will break in my car at the track that weekend!
Old Jun 3, 2004 | 02:24 AM
  #76
Rob Raymer's Avatar
sorry off topic
Old Jun 3, 2004 | 05:45 AM
  #77
LINGENFELTER SS's Avatar
sorry off topic
Old Jun 3, 2004 | 08:04 AM
  #78
sorry off topic
Old Jun 3, 2004 | 08:07 AM
  #79
Scalpel's Avatar
sorry off topic
Old Jun 3, 2004 | 09:15 AM
  #80
buschman's Avatar
Here's a hint:
