Boosted LS7 intake manifold
Old Mar 15, 2015 | 11:24 AM
mistafosta's Avatar
Default Boosted LS7 intake manifold
I was looking at intake options today for a boosted ls7 headed car and they are pretty slim pickings. I've got a ported ls7 for now, but was wondering what my choices would be for an upgrade? Holley long runner is gonna be tight (and I personally hate the look of that intake) and it seems like the only single plane options under $1000 isn't really an upgrade from the ls7. (Not looking to spend 1000+ on an intake)
Any suggestions? My current ported ls7 is on loan, so I'll need to replace it eventually. Just looking at options.
Old Mar 15, 2015 | 12:36 PM
JoeNova's Avatar
Restricted User
I personally don't see an LS7 intake as ever being a restriction unless you're running more cubes than an LS7 does.
Old Mar 15, 2015 | 12:41 PM
mistafosta's Avatar
Id prefer not to put 25+psi to a composite manifold too often.. And I'm not sure the ls7 manifold is that well set up for over 1200rwhp
Old Mar 15, 2015 | 12:45 PM
JoeNova's Avatar
Restricted User
The composite intake will stand up to 30+ PSI.
The intake doesn't care how much power you're making. It only needs to supply enough air for N/A needs. Boost pressure doesn't force it to flow any extra CFM, it still flows the same CFM at a different pressure. CFM is an ambiguous term and doesn't have any correlation with pressure. Unless the LS7 is a major restriction for your engine out of boost, it sure isn't going to be a restriction with boost.
This is why there has been over 1000 HP made on the stock LS1 intake manifold, and the stock 75mm throttle bodies.
Old Mar 15, 2015 | 01:03 PM
mistafosta's Avatar
I currently make 950 with a stock ls6 intake and tb so I'm well aware of what is capable. I have to replace this manifold eventually (It's borrowed) and I'd rather put something in with room for growth instead of just buying an ls7.
Yes it's totally possible to make the power on this manifold but I'm sure there are other options that will make it easier and will be less dependant on the turbo. I'm asking for alternative suggestions, not if the ls7 will work. Eventually I'm sure I will turn the car up well beyond 1300hp so I would like an intake that isn't a bottleneck at that point.
Old Mar 15, 2015 | 01:10 PM
JoeNova's Avatar
Restricted User
Honestly, as far as price goes, the Holley is your best bet.
Old Mar 15, 2015 | 01:12 PM
LILHEMI's Avatar
just run a stock LS1 intake and throttle body. they run 7s now.
Old Mar 15, 2015 | 01:17 PM
mistafosta's Avatar
That is kind of what I'm seeing. Seems strange that edelbrock doesn't make any Proflow xt or Vic Sr for the ls7 port, and the GMPP single plane looks like it has very little plenum volume. I might just go with a Holley and eventually do a sheet metal top half. But I was hoping someone knew of some good alternatives.
Also you asked what heads I ran but changed it, figured it would be good to know for suggestions. PRC 265cc ls7 heads are on it.
Old Mar 15, 2015 | 01:41 PM
LILHEMI's Avatar
Also you asked what heads I ran but changed it, figured it would be good to know for suggestions. PortedbyRayCharles 265cc ls7 heads are on it.
fixed haha heard this a couple of times about those heads lol
