Aster Bracket Alignment Issues, Need Your Help!
Old Mar 21, 2015 | 10:36 AM
underpressureWs6's Avatar
Post Aster Bracket Alignment Issues, Need Your Help!
hey Guys Im in the process of switching from the SDCE Bracket to the Aster Bracket, i ordered both the Bracket and the Modified LS2 Water Pump from Brute Speed. problem is the belt is hitting the water pump pulley, i attached some pictures so you guys can see how far off the alignment is. thanks for any help!
Attached Thumbnails Aster Bracket Alignment Issues, Need Your Help!-img957320.jpg   Aster Bracket Alignment Issues, Need Your Help!-img955467.jpg
Old Mar 21, 2015 | 10:38 AM
I was thinking maybe the water pump pulley is pulled out too far??
Old Mar 21, 2015 | 02:37 PM
sssalah's Avatar
Had the same issue and ended up using a stock unmodified LS2 water pump.
Old Mar 21, 2015 | 03:29 PM
im going to have to try using an unmodified pump, it should just barely clear that way...
Old Mar 22, 2015 | 12:20 AM
Firehawk441's Avatar
I had the same issue.
Had them send me a pump with the pulley pulled out .100" less.
I don't know why Aster thinks he needs to pull the pulley out that far.
Old Mar 22, 2015 | 06:56 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I sent Chris a link to this thread. There are times when it appears these cars weren't built on an assembly line, as sometimes all the allowed tolerances stack up against you. Normally the distance Chris moves the water pump pulley works out just fine, it's a real pain for our customers when it doesn't work out.
Amir, let me know what you end up with, and if you need to send back the pump. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 23, 2015 | 01:53 PM
Aster's Avatar
Amir, like Bob said sometimes the various tolerances stack against us. This is a lot more than usual though. Can you do me a favor and find out the measurement from the edge of the main belt to the spot on the water pump pulley were it rounds over to the front face. I don't think I've ever seen an F-Body that should work with an unmodified ls2 pump because it would put the belt over than rounded edge and cause it to walk off when the engine started. If in your case there is enough room we can send an unmodified pump if you can send this one back to me.
Old Mar 23, 2015 | 09:27 PM
thanks guys, i'll findout the measurements and pm you, from the pictures i posted it looks like an unmodified pump should workout fine
Old Oct 13, 2015 | 12:48 PM
ramairetransam's Avatar
having this same issues with my belt hitting the pump pulley .
