Injector suggestions
Old Mar 26, 2015 | 03:38 PM
Streetracer09's Avatar
Default Injector suggestions
Whats up
I'm building a 4.8 with 799 heads and LS1 intake. It's got a billet wheel 7575 and a 4L80E. I'm looking to get it around 650rwhp with the set up.
I'm thinking a pair of Seimans Deka 80's would do the trick. I am looking for any other suggestions or experience with similar combos. Is there any place or company that I can call to find a better suit?
Old Mar 26, 2015 | 04:05 PM
lickinpink's Avatar
I think if your running this car on pump gas the 80's will get you to that power goal no problem. They are great for the price too! running E85 might be putting you at the end of the rope. I know people like denmah have pushed these to some big numbers be hes usually running pump gas and meth. I too am also curious what exactly these have been pushed to on both pump gas and E85 though cause for around $330 shipped you cant beat them.
Old Mar 26, 2015 | 05:35 PM
stevieturbo's Avatar
Originally Posted by Streetracer09
Whats up
A pair is only 2, I suspect you'd be better with at least 8 injectors.
What fuel ?
Old Mar 26, 2015 | 06:19 PM
LS1NOVA's Avatar
80's will work good on either fuel.
OverblownZ/28's Avatar
80 lb injectors will be plenty.
Old Mar 27, 2015 | 07:43 AM
BLNLS1/RX7's Avatar
These. They are Delphi 96lb. Part # 17113744.Just had cleaned and flowed by Lingenfelters. $200
Old Mar 27, 2015 | 09:01 AM
Thanks guys. That's refreshing. I have been eyeing them up and even used them before. I just didn't know if there was any better options right now.
Bln, do you have a receipt from Lingenfelter for those injectors?
Old Mar 27, 2015 | 09:57 AM
willizm's Avatar
If you plan on running e85 consider getting larger injectors. I had 95lbers and was able to make over 700whp on e85. Otherwise 80's will be good on 93 pump gas at those power levels.
