How much boost?
Old Jun 2, 2004 | 07:32 PM
quicksilverado's Avatar
Default How much boost?
How much boost is safe on a stock 01 5.7? It will be an intercooled Radix.
Old Jun 9, 2004 | 11:52 PM
tbyrne's Avatar
We stock smaller pulleys for the Radix system. Some customers are running 8-9# without any problems but that's as far as I would go with a stock bottom end. We're doing some work with one of the major magazines. They will be trying a smaller pulley to get about 10#. It should run pretty good if they don't get any belt slippage.
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
Price Match Plus policy
Old Jun 10, 2004 | 07:19 AM
NA$TY-TA's Avatar
Ran 7 for a while motor ran fine..... upped th eboost to 11 on a stock bottom end and finally blew a head gasket and took a chunk of the block with it.... if that wouldnt of went then 5 of the 8 pistons would of let go in the next 100 miles or so. Do a search under my name you will see them.....
Kyle
Old Jun 10, 2004 | 09:34 AM
amacgt's Avatar
we are running 17 lbs. with the sts kit and alchol inj.
Old Jun 10, 2004 | 09:41 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
I would say 5-7lbs is safe...not sure I would press my luck any higher then that.
Amacgt, Alky/meth injection is a whole different ballgame then just a standard IC. What are you runnning without the alky/meth injection and pump gas?? Also your running a turbo, which is going to be different then a blower system.
Jose
