new thread, new video
Old Jun 3, 2004 | 11:45 PM
Mike 01WS6's Avatar
Holy ****! That car is sittin LOW! What did you do to lower it....cut springs? New springs? Do tell.....
Old Jun 3, 2004 | 11:49 PM
2_wacko's Avatar
Awsome video bad azz car.
Old Jun 4, 2004 | 07:09 AM
MIGHTYMOUSE's Avatar
qa1 front springs, v6 rear springs, qa1 shocks.
car sits pretty level about an inch gap above the tire with my normal wheels on it.
when you put the skinnies way out there it lenghthens the lever arm so it compresses the shock more/makes the car sit lower at the same weight.
Old Jun 4, 2004 | 08:08 AM
NA$TY-TA's Avatar
The vid was cool David.... the angle did get kinda old but cool vid anyways..... Good work on the editing Mike.
Kyle
Old Jun 4, 2004 | 01:36 PM
Malicious's Avatar
Was the track slick or just having problems getting the car to hook? Someone told me a while back that they had better traction off the line if they didnt roll the burnout out, jus cooked em and then just pulled forward... if you get what I mean, that may be totally confusing *shrug*
Old Jun 4, 2004 | 01:57 PM
Black LS1 T/A's Avatar
Moderator
Nice work.
The car DOES seem to orient itself quickly, even if your 60' is not great.
Hopefully you'll figure it out!
Old Jun 4, 2004 | 02:01 PM
kp's Avatar
kp
Nice, after watching it a couple times all the text on my computer looks like its on a 45 degree angle though I think a good set of real slicks will help you a lot..
Old Jun 4, 2004 | 02:03 PM
malicious, i know what you mean and i can certainly give it a shot.. im open to any suggestions..
maybe the tires are just old.. but i've thrown lots of adjustments on the car etc. and it still seems to just overpower them... even if i bog it off the line they start spinning about 20' out.
buschman's Avatar
hahaha, you guys are too much
Old Jun 4, 2004 | 02:17 PM
SilverGhost's Avatar
Motorboater
i see people do that every now and then and i don't get it. if you just stop the burnout and let the tires sit then pull forward you'll have water on them. the point of powering out of the box is to avoid that problem..
Old Jun 4, 2004 | 04:52 PM
NJSPDER's Avatar
nice vid man!!!!
later
tim
Old Jun 4, 2004 | 08:23 PM
  #32
CHRISPY's Avatar
cool vid!! Ditto on the angle thing hehehe
Old Jun 5, 2004 | 01:52 AM
  #33
Malicious's Avatar
Hehe got the first confused one
Pull into box, spin tires once over to get them wet, pull out to front of box where tires are OUT of the water.... Light em up and get em good and hot and instead of letting off the brake and continuing to cook the tires while moving forward, get em hot and then just ease forward. Certainly NOT leave water on the tires
