high compression e85 turbo step in
Old May 9, 2015 | 05:15 PM
cr250r's Avatar
Default high compression e85 turbo step in
Putting togather a all aluminum 5.3l tsp stage 2.5 heads forged rod pistons, tick stage 2 5.3l turbo cam compression should be 10.4-10.5 i plan on running 5lbs pump gas 20-22 on e85 is this achievable? Turbos will be s360 .88 a/r
Old May 9, 2015 | 07:47 PM
thePunkville's Avatar
sub for comments
Old May 10, 2015 | 09:25 AM
Meth Sled's Avatar
We ran 8 pounds on pump gas with no issues with a comparable compression with no issues, so on E85 you should see no issues with it.
Old May 10, 2015 | 02:37 PM
cr250r's Avatar
Okay appreciate it whats the max you have run on the e85 out of curiosity
Old May 10, 2015 | 08:12 PM
IronBlocked's Avatar
All of it
Old May 11, 2015 | 05:20 AM
S_M_I_D_D_Y's Avatar
11.5:1 comp 22psi boost 1009rwhp
ran 155mph on 18psi @ 3950#
loved it
Old May 11, 2015 | 10:37 AM
9sectruck's Avatar
11.3comp. stock bottom end ls2 19psi on e85. it flat moved... rods didn't like it very long. guessing around 850-900 to the tire
Old May 12, 2015 | 07:32 AM
cr250r's Avatar
This is good stuff guys were the cams you guys running 19+ psi big or small cam?
Old May 12, 2015 | 03:04 PM
Forcefed86's Avatar
5lbs is nothing.
Matt was running 21-23lbs on pump gas with a little meth injection at 10.5:1(ish) 5.3 with the china single 88mm turbo.
https://ls1tech.com/forums/forced-in...billet-25.html
