Recommendations on Lq4 turbo/240sx swap
Hi I am looking for a recommendation on a few parts to complete my turbo Lq4/240sx swap.
Current parts list:
2005 Lq4
Ls1 Intake Manifold
Gto Oil Pan
Microsquirt v3 (planning on using Denmah's 5.3 tune as a base map)
80lb ev6 siemens deka injectors
Garrett gt4082 turbo
Turbonetics Evolution III Wastegate
Tial Bov
Essex Fpr
Q45 Diff with a 3.54 Final gear
Spec twin disk clutch, pressure plate, and flywheel.
99 Camaro T56
B&m Ripper Shifter
I am looking for:
a good cam for boost. (Ls6 or Ls9)
Valve springs (Pac 1218 or Ls9 springs)
Rocker Arms Trunion kit
Many people say go with both the ls6 and ls9 cam. Which one would be better for my application?
Is it necessary to use pac springs with a factory cam?
People upgrade trunions because the needle bearings fail. Are there any other parts I should upgrade/replace due to failures?
I want to achieve a reliable 500-600 hp with a decent power band on 93 octane. Am I on the right track?
Thanks Steve
Current parts list:
2005 Lq4
Ls1 Intake Manifold
Gto Oil Pan
Tial Bov
Essex Fpr
99 Camaro T56
B&m Ripper Shifter
I am looking for:
Thanks Steve
I would say LS9 cam, however, they are front sensor cams versus the gen. III rear cam sensor, like what your motor is. It will run but have some issues. Also, LS9 springs don't work on anything BUT LS9 heads, I found out the hard way.. The LS6 cam will perform, and you can get away with LS6 springs as long as you don't run into valve flutter. Trunion upgrade is a must to me, cheap insurance. What head gaskets are you going with? And ARP head fasteners?
Thanks Steve
LS6 cam would be a much better choice if you can find one these days. The LS9 cam has aggressive lobes. I wouldn't run LS6 springs with it. Personally I'd jump right into PAC1218 springs. Then I'd look into aftermarket cams. If you want cheap... There are some $290 SpeedMaster USA cams that would work really well.
This would work very well IMO.
http://www.ebay.com/itm/181735579201?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
LS9 gaskets and ARP studs are the way to go on the top end.
The GTO/LS1 or any centrally located pickup pan is an issue IMO. They tend to uncover the pickup on hard acceleration. I'd order an improved racing baffle kit for the GTO pan. ($200) Or just buy a rear sump pan. (about the same price.)
http://www.ebay.com/itm/171680510219?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Chevy LS1 LS6 Fabricated Drag Front Sump Oil Pan Pickup | eBay
I can't remember but I think the rear sump pans don't clear the k-member.
LS1Tech Sponsor
Yup, 240SX requires a front-sump oil pan.
Chevy LS1 LS2 LS6 Hydraulic Roller Tappet Camshaft 561 578 Lift | eBay
