Wiseco Or Diamond pistons?
Old May 31, 2015 | 01:34 AM
Defined1983's Avatar
Originally Posted by Mongoose350
At 25# you need to look into rods as well.
already have eagle rods
Old May 31, 2015 | 08:35 AM
00Wildcat's Avatar
I would highly recommend talking to your machinist about balancing your rotating assembly. I would also highly recommend at least a .200" tool steel pin and thicker would be better. I would ask him about the advantages of the wiseco's shorter pin design which will come into play on the balancing. 408's are hard on piston skirts and cylinder walls. The ring pack as well as the pistons will be happier with a shorter stroke. I'm an E85 nut swinger, if its available within any reasonable distance I would upgrade the fuel system and run corn with 10.5-11.5 to 1 compression.
Old May 31, 2015 | 08:57 AM
thank you. i will definitely find a reputable machine shop and see what they can do for me as i'm wanting to do this right the first time
Old Jun 1, 2015 | 04:23 AM
itsslow98's Avatar
I beam or H beam?
