LS 280Z Build
Also installed wired up the new head light harness and installed the new H4 head lights. New head lights ruined the old school look. I had to take them off immediately and bought factory replacements.
Aft pass side brake started dragging and I lost a bunch of pedal pressure last outing in it. Need to see what the deal is. New brakes all around I’m sure... never ends!
The pass side rear brake drum had some light weight hardware store spring on lower shoe spring. Caused the "adjuster screw assembly" to fall out and get caught in the drum and drag. Found more of the same BS on the driver side. Here they bent up an upper (shoe return spring) and it was ready to pop off at any time.
Replaced both lower springs with new correct parts and the brakes work great again.
Monster studs on these axles! .690" diameter.
With the wheels off I was inspecting the fuel system. Crawled along the length of the car and noticed there is no filter post pump! Pulled the pre pump filter and found it was a 10 micron paper element. (Full of crap I might add) I'm sure this is why the Holley 1800 was louder than I thought it should be. What kind of moron puts a 10 micron filter pre-pump!
So I pulled the pump. Upon doing this I found the power and ground wires to the pump had melted wire shielding. Relay plug was also melted at bit. All poorly crimped wires with corrosion all over them.
So I ran all new heavy gauge wire (shrink wrapped) with a new 30A relay and soldered everything.
Waiting on new filter element, pump mount isolators, and new fittings and lines to make a pump supply line. I pulled the pump apart and it was very clean with no signs of heat or damage to the pump rotors. The pump wiring itself also looked great. No signs of heat on the wires or at the pump motor.
http://documents.holley.com/199r10573-1rev.pdf
