Bosch 044 pre filter?
Old May 30, 2015 | 05:06 PM
3 window's Avatar
Default Bosch 044 pre filter?
I'm going to be running dual 044s on E85. Does anyone pre filter these pumps? I know they have a screen, so I was thinking of just post filtering. Let me know if you do and what filter you use. Thanks
Old May 30, 2015 | 05:39 PM
LT1PWRD's Avatar
XRP makes a 120 micron screw in screen for the 044. I run it as well as the XRP 10 micron post filter. Excellent quality and cleanable.
Old May 31, 2015 | 02:03 PM
stevieturbo's Avatar
Whilst just normal fuel, I just use a Holley 40 micron in front of each pump. No other filters in the system, never any issues.
For a long time I only had a single 100 micron Aeromotive before both pumps again never any problems ( tank only has a single outlet )
Some injectors can be very fussy about filtration though, so that may force you to use an additional filter. Although with something like the decent sized Holley or Aeromotive type filters, I wouldnt see any issues running a 10 micron in front of the pump and none after
As the filter will be gravity feed I'd definitely choose a high flow item with good capacity and not something small and shitty. I see pictures of people using really small filters intended for a carb application, which is mental considering the volumes of fuel that move in an EFI system.
There is never anything bad about oversizing a filter, especially when there is nothing pushing fuel through it. EFI pumps do not suck well
