S475 still having back pressure issues??
Old Jun 1, 2015 | 05:40 PM
Phish806's Avatar
Default S475 still having back pressure issues??
Now the setup i have is a lq4, ls3 topend,cam and a s475 with a 83 trim turbine. I had back pressure issues with the previous turbo i was running (Comp 8079...imagine that) so i swapped it out to the S475. I understand that the 83 is a little small for a 6.0 still but i am not looking for high boost or numbers. After all its a stock Lq4 bottom end. The most It would ever see is 15 psi.
Moving on, i got the turbo installed and logged back pressure ad its still high. were talking 3:1 and at sometimes spiking 4:1 on 5 psi. I tried removing the exhaust thinking its a restriction and just running the downpipe. It made little differnce. Maybe dropped it a pound or two, but still crazy high.
Another thing that i found odd, is that when its coming into boost, you will see around 0.2 lbs of boost and already have around 5psi of back pressure in the exhaust manifold. This doenst seem right to me, but maybe its normal?
I am really out of ideas now. My last one would be that the intercooler is causing a restriction??
I also understand that i am doing pulls on low boost... around 3-5 psi. Would the back pressure keep climbing as i turn the boost up or would it keep itself in check? I know that backpressure is supposed to get worse as psi increases, but at this point, i am doubting myself at every turn.
PS... were talking pre turbo pressue. The sensor gets its reading from the drivers side manifold where the stock o2 sensor would be.
If anyone has any ideas of help i would greatly appriciate it. thanks.
Old Jun 1, 2015 | 06:26 PM
JoeNova's Avatar
Restricted User
Which turbine housing? What A/R?
What cam?
What size downpipe?
Old Jun 1, 2015 | 06:34 PM
SPRAYED 01's Avatar
Could be a boost leak. Your comparing the difference in the psi in the intake compared to exhaust. What if the intake psi was off because of a good size boost leak?
Old Jun 1, 2015 | 06:38 PM
Phish806's Avatar
t4 1.10 ar
cam is a 223/231 .615 .598 on a 115+5
Downpipe is a 3.5" downpipe
full exhaust would be the downpipe going to behind the trans splitting into two 2.5" duals and going out though a "straight through" muffler in each
Yes, it could be a boos leak, but it would hav eot be quite large. I will have to boost leak test it again. However i did when the comp was on the car, and all checked out fine.
Old Jun 1, 2015 | 07:09 PM
JoeNova's Avatar
Restricted User
Your turbine is small, but still not small enough to cause that much backpressure on low boost. I typically try to stay away from smaller turbines anytime I go with an aftermarket cam, especially one that size because backpressure can be more of a problem.
Check for boost leaks. Where are you getting your boost reading from?
Old Jun 1, 2015 | 07:22 PM
Phish806's Avatar
The boost reading is coming from one of the ports behind the TB on the passanger side of the intake. It was drilled and tapped and now goes from an NPT to an AN fitting. Then the hose is going to the map sensor mounted on the firewall.
Old Jun 1, 2015 | 09:05 PM
slowride's Avatar
I think he is asking where you are measuring the back pressure. Sometimes certain locations might distort the numbers due to being in a tight bend etc
Old Jun 1, 2015 | 09:21 PM
Phish806's Avatar
I am coming off the drivers manifod where the factory 02 sensor would be. You can see the aluminum line i have coming off the manifold in the pic
Old Jun 1, 2015 | 09:33 PM
slowride's Avatar
Not sure how well that location would be. In test cells we would always be a few inches from the turbine housing but that will require drilling.
Old Jun 1, 2015 | 09:49 PM
SPRAYED 01's Avatar
All my testing was done tapped very close to the turbo flange.
Old Jun 1, 2015 | 09:52 PM
Phish806's Avatar
I was told that any place in the manifold would give you a correct pressure reading. Basically, the hotside would be the same pressure no matter where the sensor was. Now, is this wrong?
Old Jun 2, 2015 | 09:16 PM
Phish806's Avatar
Did a boost leak test. All i had leaking was a tiny tiny leak at the IAC valve. Other then that it was solid. I was actually pretty impressed. Now i am unsure of a direction to go...
Old Jun 2, 2015 | 09:59 PM
fastbarry's Avatar
try reading back pressure at or right near the turbine flange.
it appears that you are reading from between the third and fourth port in the exhaust manifold?
pressure waves near the exhaust port can exceed 1000 psi when the exhaust valve opens. how far is the gauge port from an exhaust valve? i believe this may be skewing the readings.
i would move where you are taking your reading and see if you observe the same or different drive pressure numbers while changing nothing else.
Old Jun 2, 2015 | 10:06 PM
rotary1307cc's Avatar
Do you have a rag in the IC? Lol
Old Jun 2, 2015 | 10:07 PM
Your pickup for the pressure is fine and fumctional
Old Jun 2, 2015 | 10:24 PM
Phish806's Avatar
Then what could be my issue.... only thing i can think of is how i built the crossover and maybe where it merges together is messed up. But i know its not bad.... i will try and find a pic
Old Jun 2, 2015 | 10:35 PM
Phish806's Avatar
i couldnt find a decent pic. there are some in the build thread. Basically a ton of pics on the first page that you guys can check out.
https://ls1tech.com/forums/forced-in...o-lsx-rx7.html
Old Jun 3, 2015 | 06:16 AM
forcd ind's Avatar
Curious, being new to turbos, how do you know when you have a BP problem, is there a certain # you look for-I would think with a turbo all
that exhaust going thru a small opening would create some BP
Thanks
Old Jun 3, 2015 | 06:20 AM
69-chvl's Avatar
So when you guys are measuring backpressure, one bank's readings is all that's needed? For a divided system too? I figured the turbine housing would of given a more accurate reading as the banks are combined at that point.
Old Jun 3, 2015 | 08:16 AM
LJMSJohn's Avatar
Yea... i wouldnt be getting pressure readings in the manifold.... id be near the turbine entry....
