Low coolant after turbo install.
Old Jun 2, 2015 | 09:44 AM
Randolph Ziskey's Avatar
Default Low coolant after turbo install.
After driving the car around without any problems I encountered a spot of coolant on the floor. I began searching for source and it appears it is coming from where the turbo meets the stock radiator. I don't beeline there is a crack but I am not certain. I checked the level and about half of the radiator fluid is gone. The car has not over heated once. Anyone encounter this?
I have the Huron speed v1 ac kit with precision turbo 7475. Any advice would be appreciated.
Old Jun 2, 2015 | 09:45 AM
Camera phone shot sucks but when I touch that area my fingers get coolant all over them.
Old Jun 2, 2015 | 09:48 AM
There is drops of coolant on on the coupler and the lower part of the radiator.
Old Jun 2, 2015 | 09:49 AM
The hoses all check out so far.
Old Jun 2, 2015 | 11:04 AM
Atomic's Avatar
I need a gauge for that
There is actually a gasket around the end tanks on the radiator that could possibly leak. Mine did at one point.
Old Jun 2, 2015 | 12:08 PM
jrpimp00's Avatar
Your turbo rubbed your radiator causing the hole. Possible on installation. Mine did the same thing. I found the hole and JB Welded it up. Been fine for over a year
Old Jun 2, 2015 | 06:17 PM
Superman09's Avatar
LS1Tech Sponsor
Check your radiator for damage as the clearance is tight on the V1 A/C kits, they nick easily if not very careful on install. A pin hole there could be the culprit. Keep us posted and if I can do anything to assist as always feel free to ask!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 2, 2015 | 09:05 PM
Black89Z51's Avatar
Fill up the radiator and put a pressure test kit on it. Look in the suspect area for water coming out.
Old Jun 2, 2015 | 09:15 PM
Thanks for the responses guys!!!
Old Jul 2, 2015 | 07:31 PM
Well turns out the turbo hit the radiator.
Old Jul 2, 2015 | 07:32 PM
Got it squared away. Looks like plenty of room now compared to before. Thanks to Jon at Huron Speed for the advice!!
