Thoughts on EGT probe location needed...
Old Jun 5, 2015 | 06:44 AM
SpeedJunkee's Avatar
Default Thoughts on EGT probe location needed...
I am wanting to install my EGT probe on my turbo LT1 I am working on. I had this previously on my supercharged setup and it was a nice tool to monitor and reference my temps. I would like to use it for the same on my turbocharged setup. Before I had the sensor located just downstream of my Y-pipe. Reading the manufacturers reccomendation for a turbo setup, it says it should go closer to the heads and before the turbo. I don't really like this idea, as if it breaks it can go through the turbo.
Again, I am not using this for tuning, just for reference and monitoring. Do you think I would be alright installing it in the downpipe or slightly further back in the exhaust?
Old Jun 5, 2015 | 10:23 AM
WSLN 6's Avatar
Nope...... Pre turbo flange is where you want to be, keep it under 1650....
Old Jun 5, 2015 | 12:09 PM
TurboBuick6's Avatar
This.
Old Jun 5, 2015 | 01:27 PM
Okay. Why though?
Old Jun 5, 2015 | 03:21 PM
stevieturbo's Avatar
For reference, it will be fine after the turbo, and there is no risk of it breaking off and killing the turbo.
For tuning yes ideally it would be pre turbo though, but still not essential
Old Jun 5, 2015 | 05:09 PM
This was more or less what I was hoping to find. I am not using it for tuning, it really is just a reference and something to monitor.
The only problem I could see is possible EGTs exceeding the probes limits if I place it too close to the turbo perhaps. But I don't know if the temps near the heads would actually be more hot than the temps in the downpipe?
I am also trying to figure out the limits of my probe.
Old Jun 5, 2015 | 05:21 PM
Temps pre-turbine will be hotter than post turbine, which is why it is preferred as a more accurate picture of what's going on.
But for most part you're looking for consistent readings and changes.
If you know it always runs at say 1400degF post turbine and is safe at this....if it suddenly jumped to say 1600degF, then you know something has went wrong
Above numbers are purely an example, every setup can be different.
Old Jun 5, 2015 | 07:16 PM
Thanks stevie. Good info! For what I want it for and the safety of if the probe fails (and having it NOT go through my turbo), I much prefer the downpipe idea. Perhaps knowing about the temps, I can plan on running the probe a little more closer to the turbo in the downpipe than further back like originally thought.
Old Jun 6, 2015 | 08:28 AM
NitrOmm's Avatar
Good information.
( please excuse the hijack. I can't seem to find much info on this subject).
For my new Procharger build I'd like to have EGT readings for reference as well. In a true dual set up will I need to have two separate sensors ?
This is also not for tuning ..., just a benchmark monitoring device for say .... Meth pump decided to stop being a meth pump or AFR is out of wack etc..
Thanks
Old Jun 6, 2015 | 08:44 AM
Originally Posted by NitrOmm
Good information.
Thanks
My previous setup was a Procharger. A single EGT probe will suffice. Mine was located just downstream of my 02 sensor in the car. It will reflect the temp changes of something goes wrong.
Old Jun 6, 2015 | 09:54 AM
WSLN 6's Avatar
A little thicker probe will respond a little slower, but give you piece of mind for reliability pre-turbo if you are concerned. We have run them over 1800 deg, with no problems whatsoever....
Old Jun 6, 2015 | 04:21 PM
Naw, it doesn't make sense to run it pre turbo and risk it if its not needed for tuning from what I am seeing. Besides, I already have an EGT probe and it saves me a little not having to buy a new one.
