Some e85 boost ?s
Old Jun 7, 2015 | 12:38 PM
2JZFC's Avatar
Originally Posted by 93camaro_zzz
At least 160's?!?! Jesus man, I am running a 9.15 with 18psi of boost on siemens 80#'ers on ethanol. I had to raise my base pressure though. But you are going to be more than fine on a set of Bosch Hi-Z 127# injectors. That is a good and fair priced injector.
The Bosch 127# injectors are very nice, but be aware that the 127# flow rating is at 58psi, not the industry standard 43.5. They flow more like 115# at 43.5psi. Yes, you can jack up the base pressure to increase flow but also be aware that fuel pump flow decreases as fuel pressure increases. IOW, if you jack up the FP to get the injector to flow more, you might run out of pump.
Manufacturers like to toss out high flow numbers to get your attention, like "this pump supports 2000hp". Yes it does, at 8psi for a carb setup in the lab, but what does it flow at 75psi in the car when voltage is down to 13V? How many vendors/manufacturers publish flow charts for their pumps?
Sorry, one of my pet peeves. Carry on.
Old Jun 7, 2015 | 01:02 PM
RonSSNova's Avatar
2JZFC has it exactly correct. It becomes a pump/injector balancing act when trying to move from gas to E85 on an existing setup.
Old Jun 7, 2015 | 09:02 PM
mkvamso's Avatar
What those guys said
My tuner said he's had pretty good luck at the base pressure its at with setups similar to mine
Dual 340s and 84lb injectors, not so much pressure that the pumps start to fall off,but enough to keep up with the smallish injectors
I think there rated at 43psi so they're just a little bigger than the popular Siemens 80s
I probably won't turn mine up much more than it is, pretty happy with the fuel system for not having spent too much
Old Jun 7, 2015 | 09:22 PM
LT1PWRD's Avatar
Originally Posted by LT1PWRD
Am i correct in saying, on a gas scale, if i tune for 11.5, this would be the same safe afr for e85 ?
And my DC would increase on it's own to satisfy the commanded afr and extra fuel needed,correct?
Provided my injectors and fuel supply could keep up of course.
bumpy...
Old Jun 8, 2015 | 10:45 AM
93camaro_zzz's Avatar
Yeah good point 2JZ, they are rated at 4 bar. And I was running triple walbro 255s for my fueling. I used to be on just twin 255s, but I was getting really worried about running out of pump.
I am having trouble understanding the question I guess. I think what you are meaning to say is, if you target the 11.5 (gas scale) afr for your e85 setup, you will also have e85's stoich ratio of 9.77 programmed in you ECU also, so yes, when you get into WOT higher boost areas, you will see that the duty cycle has gone up by quite a bit. I also like to keep an eye on the fuel pressure at least at first, so you can see if you are running out of pump.
Old Jun 8, 2015 | 10:47 AM
Yeah definitely Ron, all while also playing the money game! haha
Old Jun 9, 2015 | 07:03 AM
LT1PWRD's Avatar
Yup, that's what i was askin.
But wouldn't i actually be getting 6.5 under boost conditions If i using an 11.5 afr scale?
Should I set base around 75? Keep in mind im running a single 044. If my DC gets outta control ill add another in parallel.
Old Jun 9, 2015 | 12:16 PM
OldGold's Avatar
I have SD 80 pounders in a 5.3 with a Holley 12-1800, Billet S366, LJMS custom cam. I have more than enough fuel at 16.5 psi. As a matter of fact, I keep trimming above 5500 rpm. While it is "only" a 66mm turbo, it is a Forced Inductions V2 wheel and it is rated for 1k. Car made 540 with the same turbo with a cast wheel at 11 psi. I don't think you need 160 pound injectors for a 5.3 on corn, unless it is a max effort car with a large turbo.
Old Jun 10, 2015 | 12:19 PM
Nope. (11.5/14.63)*9.77 = 7.67:1 AFR.
Also you absolutely will not have enough fuel flow to raise your base pressure. You need more pump.
Old Jun 10, 2015 | 05:46 PM
Spectre86's Avatar
Whats you injector/pump/fuel line setup? I remember you saying your running E85. Im moving at the end of the year and by the time my car is done, Ill be near an E85 station.
Old Jun 11, 2015 | 09:31 AM
SwampWS6's Avatar
Originally Posted by willizm
Before cranking it up you should log your car to see what sort of DC you are using on lower boost. FWIW if you have an electronic fuel pressure gauge you could splice that into an hptuners pro box to log for any drops as you push more boost. I run 2000cc injectors and on 16psi I'm seeing about 70% dc and steady pressure on dual 340 pumps. I plan on pushing 22psi later this fall so i'll be watching my Lambda, fuel pressure and injector dc as I work my way up there.
Do you have a build thread willizm? Im so infatuated with your car/setup. Is that weird?
Old Jun 12, 2015 | 09:40 AM
  #32
LT1PWRD's Avatar
Ahh, so 7.67 is on the lean side. What should I shoot for in boost?
Well, i ran outta pump like you said i would. I tried some e85 and watched DC under wot and hit 100% almost instantly. So, gotta redo fuel system. since im a non oe efi car. (70 Chevelle) Im gonna add another 044 to my sumped tank or do a surge tank setup.
Like this to 2 044s......
Or this......
Old Jun 12, 2015 | 02:02 PM
  #33
Spectre86's Avatar
Im in the middle of doing mine as well. two 044s and a 450 intank.
http://www.proflow.com.au/catalog/500417
That's the setup im looking at for the 044s.
Old Jun 13, 2015 | 06:11 PM
  #34
LT1PWRD's Avatar
Who sells these in the states?
Old Jun 14, 2015 | 12:02 AM
  #35
Detoxx03's Avatar
I'll be running ID1300s. They just arrived yesterday as I already had the rest of my new fuel system waiting.
Old Jun 14, 2015 | 02:21 PM
  #36
LT1PWRD's Avatar
Or this.....
