can Anyone can help me with 2step wiring off clutch
My car is a 1995 camaro z28 have a m6. I recently bought a msd6al 2 box so i could run a 2 step on my setup.. i tried to do research after research and could not find a answer to this question.. I wanted to run my 2 step off my clutch pedal where is would activate it when i have my foot on the clutch... does anyone have a diagram or picture they can post or tell me how to wire this up...plus is there a certain way u have to wire it up because if i were racing and go to shift into 2 gear lets say when i put my foot on the clutch would it activate the 2step -- i know theres a way u wire this up because i had a shop install one on my 94 camaro years ago and it was off the clutch and it would not interfear between shifting if u know what i mean... please please help...driving me crazy trying to figure this out...
I have a button on my shifter for line lock, and a brake lite switch that is mounted to the clutch linkage belcrank for a clutch switch.
I use relays for each, and I wired them so that the clutch switch 'Latches' the linelock relay.
I have the 2 step connected to this, but through a dash switch so I can disable it for burnout.
Badically it required 2 relays, 1 brakelight switch and 1 toggle switch and works like this:
I do burnout
Toggle on the 2step switch
Roll into the prestage beam
Press brakes lightly then press line lock button and hold it.
Bump clutch untill I light the stage bulb, then press clutch to floor and release lineloc button AND go WOT
Then I release clutch pedal to launch.
I do burnout
