Cam Question for ls1 procharged
Old Jul 27, 2015 | 06:19 PM
toxshox's Avatar
Default Cam Question for ls1 procharged
I'm wondering if this cam I already have is a good choice for a p1sc-1 ls1
Specs are
Duration Intake 224.5 Exhaust 226.6 Valve Lift Intake .566 Exhaust .573 and lobe separation is 114.6
If there are better cams numbers out there I'd appreciate some advice and what might this cam I already be used for? I originally bought it for a motor project on a 6.0 that never got finished. Right now the car has a texas speed performance magic stick cam in it I'd have to try to find the specs on it though not to sure how it would work with boost?
Old Jul 27, 2015 | 06:44 PM
HCI2000SS's Avatar
The magic stick cams are not going to do well with any significant boost. With that said the other one you've listed looks pretty good based on the specs
Old Jul 27, 2015 | 07:36 PM
toxshox's Avatar
something better out there at all for numbers, should i look for something with a bit more duration or lift? my future plans is just put a lsx motor in the car. that one i have laying around is a thunder racing custom grind?
Old Jul 27, 2015 | 07:39 PM
HCI2000SS's Avatar
What motor is this and what vehicle? How much boost will you be pushing?
Old Jul 27, 2015 | 08:03 PM
toxshox's Avatar
it be a stock block ls1 has stg2 heads long tube headers and a 92mm intake tb and 100 maf in a 01 trans am 6 speed. I'd like to run as much boost as the p1sc-1 can do. If I can blow the motor I'd have a reason to put that lsx in it then. I'd probably aim for 10+ try to get close to 15. If you think that cam can achieve close to that boost I'll throw it in and see what I can do.
I haven't driven the car in like 3 years so I have a new itch since I drove it.
Old Jul 27, 2015 | 08:34 PM
HCI2000SS's Avatar
Gotcha. I'd check out Brutespeed for the best option on a blower cam. They seem to specialize in this particular area from what I've read
Old Jul 28, 2015 | 10:37 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thanks. My blower cam would work very well with the op's combination. Here is a link to it. http://shop.brutespeed.com/Brute-Spe...d-Camshaft.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jul 30, 2015 | 10:21 AM
toxshox's Avatar
Thanks for the link. this one would be a little to much?
http://shop.brutespeed.com/Comp-54-4...-54-478-11.htm
Old Jul 30, 2015 | 10:48 AM
LS1Tech Sponsor
54-478-11
HYDRAULIC ROLLER-Good high rpm power when used with a centrifugal blower
I'd say for your combination our Brute Speed cam would give you more all around performance than the 54-478-11, as you would lose low end and mid range power with the 54-478-11.
We used this same 232/240 595/608 on 115 lsa cam in my Camaro.
Thanks. Bob
__________________
