Project Cocaine
Old Aug 1, 2015 | 06:28 PM
ScreamingL's Avatar
Changing Names
Default Project Cocaine
Lsx427 build
Twin precision Billet 7675s
mast 295 heads
oliver billet I beams
dragonslayer
Billet atomizer3 225lb injectors
belt drive fuel pump
list goes on
Old Aug 1, 2015 | 06:29 PM
ScreamingL's Avatar
Changing Names
4l80e that had built
Old Aug 1, 2015 | 06:30 PM
ScreamingL's Avatar
Changing Names
little block action
Size:  124.6 KB[/QUOTE]
Old Aug 1, 2015 | 06:32 PM
ScreamingL's Avatar
Changing Names
heres a pic of my Mast heads being drilled for 1/2 studs
Old Aug 1, 2015 | 06:33 PM
ScreamingL's Avatar
Changing Names
the mast 295s have a 2.25 intake valve
ive measured the ports and my exhaust port measures 1 13/16 x 1 3/4
my intake port measures 1.260 x 3.250
if you look at the pics my holley Hi ram is much smaller and will need to be ported
I measured that as well and it comes out to .95 x 3.1
Old Aug 1, 2015 | 06:34 PM
ScreamingL's Avatar
Changing Names
Paid the machine shop a visit and brought home the heart for Cocaine
Old Aug 1, 2015 | 06:40 PM
ScreamingL's Avatar
Changing Names
a run down of motor
Mast 295cc 12* cathedral heads
Diamond ls7 pistons
Callies dragon slayer
Oliver billet I beams
ARP 1/2" head studs torqued to 120ftlbs
ATI super damper with aluminum hub
cam 235/243 646/664 114+4
compression is around 9.68:1 i wanted 10.0 but head swap dropped it
Ported Holley Hi-ram 102
LSX block
Lunati Tie bar lifters
ARP mains hardware
Old Aug 1, 2015 | 06:45 PM
CWIZZLE's Avatar
Yes please!!
Old Aug 1, 2015 | 06:46 PM
ScreamingL's Avatar
Changing Names
did get a chance to order my turbos and they finally showed
precision 7675 cea .96ar
ScreamingL's Avatar
Changing Names
picked up 1/2" ss LS header flanges made for sch10
picked up 1/2" ss 3" tube to t4 turbo flanges
twin billet 7675s .96ars
ams500
twin precision 46mm gates
twin tial 50mm bovs
biondo co2 kit
setup is gonna be all aluminum tubing
ScreamingL's Avatar
Changing Names
turbos mounted already
Old Aug 1, 2015 | 06:53 PM
ScreamingL's Avatar
Changing Names
My new chromoly front support
The lower part weighs in at 8.5lbs
I still have to make tabs to secure lower part of bumper cover and couple outriggers for the rad support
If you're thinking what all the stock weighed in at...it was around 60lbs not counting the bumper
O btw the long bolt with spacers arent permanent, used what i had till i can go to hardware store
Old Aug 1, 2015 | 06:54 PM
ScreamingL's Avatar
Changing Names
went ahead and had a few things jet hot coated
ScreamingL's Avatar
Changing Names
couple pics here of the manual rack, tubular motor mounts and how the fuel pump sits inside the engine bay
Old Aug 1, 2015 | 06:55 PM
ScreamingL's Avatar
Changing Names
few pics of the truck rolled outside the garage
theres no weight in the *** of the truck and gonna pick up a front coil spring spacer as the front is little lower then Id like
theres gonna be around 250-300lbs added to rear of truck with the weight from the batteries and fuel cell
Old Aug 1, 2015 | 06:56 PM
ScreamingL's Avatar
Changing Names
heres a few pics of the engine bay with the headers and part of downpipes coated, along with frame painted
ScreamingL's Avatar
Changing Names
Made some good progress today
Wrapped the Downpipes
Modded the rad (changed the filler neck)
Made mounts to secure rad to A frame
Found a fan to work with rad...(GTO AC fan)
Built my charge pipe
Size:  77.2 KBName:  charge%20pipe%202_zpszfk0rasw.jpg
Old Aug 1, 2015 | 06:57 PM
ScreamingL's Avatar
Changing Names
Old Aug 1, 2015 | 06:58 PM
ScreamingL's Avatar
Changing Names
turbos to intercooler piping is done, now its time to disassemble everything have all powdercoated and painted
Old Aug 1, 2015 | 07:08 PM
NateLS1Mustang's Avatar
This whole thread/build is badass!
