Headstuds with engine in car
Old Sep 19, 2015 | 02:38 PM
ramairetransam's Avatar
Default Headstuds with engine in car
Im thinking of taking the heads off the car this winter and having them cleaned up , new lifters , ls9 gaskets and possibly arp head studs .
If i put the heads studs in each hole can i put the heads on in my 99 formula or is their not enough room to do that . Ill be making about 13-14 lbs of boost .
Old Sep 19, 2015 | 03:51 PM
conan's Avatar
I have pulled my heads out of the car with studs in place. You might have to remove a stud or 2 but its not any harder of a job... studs vs bolts.
Old Sep 19, 2015 | 06:52 PM
thanks conan , another question can you leave all the sdce bracket in place or does it have to come off ?
Old Sep 19, 2015 | 07:33 PM
LS6427's Avatar
My heads came off my 436ci engine with head studs....no problem actually, plenty of clearance.
Old Sep 19, 2015 | 09:53 PM
conan's Avatar
J bracket can stay as well, just the power steering pump has to come out/off.
Also if your going to go through that much mess and hassle with coolant and power steering fluid why not spend an extra hour and $500 and finally get a blower cam in that thing.
Old Sep 20, 2015 | 05:00 AM
JRENIGAR's Avatar
Old Sep 22, 2015 | 08:49 AM
lemons12's Avatar
Plenty of room.
Old Sep 22, 2015 | 09:36 AM
TyCZ28's Avatar
Done it 3 times on 3 different cars with both ARP and ProComp studs. No problems at all and ALL CARS HAD A/C
Old Sep 22, 2015 | 11:45 AM
thanks for the replies guys . Guess i will be going with headstuds.
Old Sep 23, 2015 | 05:12 AM
JRENIGAR's Avatar
Good to know. I almost went with bolts instead of studs incase of a head gasket failure, because I didnt want to drop the engine/trans again.
