bunch of turbo questions for build
for a cam im stuck between the BTR stage4 and tick stage 3 turbo cam. which would you choose and why? any real world experience with these cams?
what intake would you use? ls7 based.
what turbo manifolds? i havent really been able to find anything that may work
From what I can find, in two minutes of research, is the btr stgIV is 234/239 .612/.610 115+5
And the tick stg3 is 235/243 .63x/.62x 116.5+5
So, I would see what cam motion can do in the 234/242 .62x/.62x 115.5+5 range.
As for intakes... I didn't even realize that was ever a question. What else is there besides the fast lsxrt 102? Lol.
1bdbrd. i found the info i needed off the yellowbullet and then happened to luck into a killer deal on some and pulled the trigger
The cam has too much overlap for that set-up.
