Meth Injection Without Tune Gains
There are a ton of benefits to running it even without a tune. I had a bad episode with a boost controller and wastegate in the past week. Set the controller for 10 lbs, ran 20 lbs of boost on pump gas on 3 separate pulls. The last pull, I hit 27 lbs before I let off. If it wasn't for the water/meth, I would be out looking for a new engine.
Regular blue -20* windshield washer fluid is like 68% water 32% methanol and you can get it less than $2/gallon. Not much reason not to run that.
It might be more useful to explain what you are working with, and what you are trying to achieve.
Many cases you could see losses, on the other hand in other cases you may be able to release some gains. But it always depends what you're working with in the first place.
the weather was very close to the same da. all seemed the same.
Dont get caught up with big jets etc
A small nozzle, for whatever system you chose, is going to be sufficient and you'll be fine.
