Volvo 242 - The frog
Old Oct 6, 2015 | 04:10 PM
St3v3's Avatar
Default Volvo 242 - The frog
I have previously owned two Shenandoah green/Medium green 242 from 1976.
The first one had a M50B25 from BMW E34 with VEMS ecu
The second one had a S38B36 from BMW E34 M5, also with a VEMS ecu
So when i found another one i just had to buy it
Someone had started to build a turbo B230 in it and it was in bits and pieces so i started with some rustrepair on the floor, and it was a quick job because there wasnt any
Got the interior together
Made it driveable and got it thru inspection(and then it is road legal for two years)
Old Oct 6, 2015 | 04:11 PM
St3v3's Avatar
Same day as the inspection i threw the B20 out and started to fit the new engine
5.3 LM7 from a Tahoe
Not much space for the truck intake, had to cut som plastic and reinforcement on the hood
The pan needed some cutting too, and obviously i have to cut it some more
I used this device to get the engine centered in the front while i was getting it to sit like i wanted. Makes the job alot easier
Old Oct 6, 2015 | 04:12 PM
St3v3's Avatar
Today i went and bought some bling for the engine.
Super HX40, should get the job done!
Thinking about using the stock manifolds. Nice fit in the 240 engine bay
Old Oct 6, 2015 | 04:20 PM
St3v3's Avatar
Maybe i should mention that i am from Sweden...some words may not be correct
Old Oct 6, 2015 | 08:17 PM
Centerforce's Avatar
I love that color on a 240! This takes turbo-brick to a new level. Are you planning on tracking the car? Drifting? Or just building a totally awesome street car?
Old Oct 6, 2015 | 11:25 PM
rat_rod_russell's Avatar
Please tell me this is the sleeper from hell project?
Old Oct 7, 2015 | 02:58 PM
St3v3's Avatar
Just a fun street car!
The last one with the M5 engine was a total sleeper with the stock 14" wheels, stock tailpipe and even mounted the battery in a cooler in the trunk to get the sleeper look. Don´t think the 14" will work so good on this car
Old Oct 7, 2015 | 03:37 PM
DavidBoren's Avatar
I do enjoy hearing about LSx swaps in other countries.
Your other two Oscar-the-grouch-green 242's were both clean and cute with the little bmw motor in there... This one is going to be brutal and unapologetic.
It's hard to maintain any sort of sleeper status when you fill the intersection with white smoke and leave two trails of rubber all the way to the next light (do they have streetlights in Sweden? Lol).
Old Oct 8, 2015 | 05:01 PM
BudRacing's Avatar
LS Volvos are my fave. That M5 engine was pretty slick though. I like the dumped tailpipe with the decoy stock rusted tube.
Old Oct 10, 2015 | 05:17 PM
St3v3's Avatar
Started to do some plumbing today...not so complicated and should do the job
Old Oct 10, 2015 | 11:41 PM
truckdoug's Avatar
i love the engine centering tool. very creative!
Old Oct 11, 2015 | 03:35 PM
St3v3's Avatar
Old Oct 12, 2015 | 10:41 PM
PrimerDust360's Avatar
Nice! Looks like it was designed with a Turbo LS in mind. If the LS motors had existed when I had my '70 145S it would have been a no-brainer. Instead I spent more than the cost of that swap on a built B20 with 2 DCOEs, a cam and a header... Auto to M41 swap and LSD, vented rotors/better calipers off of later Volvos. It was never the fastest car but it was quick, clean and surprised a lot of people in the early 90's.
Old Oct 13, 2015 | 10:32 AM
DavidBoren's Avatar
Originally Posted by St3v3
This picture really says it all.
Old Oct 13, 2015 | 11:39 AM
lynx853's Avatar
This. Is. Awesome.
Old Oct 13, 2015 | 11:41 AM
thompson's Avatar
Very cool build! Looking forward to seeing it completed!
Old Oct 14, 2015 | 11:45 AM
schwartzmesser's Avatar
I am gonna follow this thread for sure!!!
After swapping a carbureted Chevy 350 and Camaro T5 into my 1990 Volvo 245, my next project is exactly like this... well, not exactly; I want to do a single turbo on the passenger side of the 5.3, and put it all in a 1970's wagon.
Will definitely be checking in here often while I continue to get parts collected.
Old Oct 14, 2015 | 06:14 PM
St3v3's Avatar
Anyone got a T56 from a LS1 who can be kind and measure some dimensions for me?
I need to know the following:
A. How long is the part of the input shaft that is sticking out of the bellhousing?
B. How long is the part of the input shaft that is for the pilot bearing?
C. How long are the splines?
Old Oct 14, 2015 | 09:11 PM
Project GatTagO's Avatar
I can get you B and C from a F-body trans, but no bellhousing, so not A.
Andrew
Old Oct 17, 2015 | 11:17 AM
St3v3's Avatar
Andrew
Thanks, but i think i have found someone who can get all three for me
Made some brackets for the Holset twins yesterday, the exhaust manifolds should like that
Today i started with the downpipes. Made some reductions for the 3.5" downpipes so they would fit the turbo. Used a hydrualic press and some parts from a wheels balancer
Then to the downpipes
