Opinion on this setup
Driver side valve cover barbI have the valve cover line going to the inlet on the procharger and the intake line going to my regulator for boost reference, and then my bad air line is going to the manifold bottom nipple under intake and then the TB is capped off and the bottom line of the catch can has that little air filter with a check valve , a shop set it up this way. Is this correct ? I've looked at damn near every setup and still don't understand the back of the driver side valve cover line setup because it's going to a metal tube that goes along the back of my motor.
are you open to replacing some/all components or does your budget bind you to use what you have there.
is this car mass air or speed density?
what are your goals with the setup?
-how much hp
-engine breathing?
-oil control?
-do you want to have a pcv system?
-how much hp
-engine breathing?
-oil control?
04 gto with d1 its been tuned and the shop that tuned it set it up like this I'm not worried about power at the moment considering I need the pcv and all the lines fixed to get a proper tune it's a maf but the main thing that I have an issue with is that fact that the boost reference line going to the regulator gives my bottom line on the catch can no where to go so I'm assuming the good air escaping into the atmosphere on that little airfilter is fine but it doesn't put good air back into the crank so in other words idk what to do with the last line that has the good air on the catch can (bottom line )
there is no perfect fix for your needs with the parts you have.
if you run a pcv system with MAF you will pull unmetered air through that valve cover bretaher so:
you can either get rid of the v/c breather and run the catch can between valley and intake, and fresh air from valve cover to s/c inlet - this will be pcv style
or
you can run the valve cover breather and run a line from the passenger valve cover through the catch can do the s/c inlet - this will be draft style
you still need to figure out what the heck is going on with the hard line at the firewall. if it is evap it needs to connect to an evap solenoid down the drivers side of the intake manifold with a 2 pin plug connected to it and then vac hose from the end of the solenoid to the intake manifold.
you can tap for boost anywhere on the intake, its clean to do it at the rear, and there is already one hose you could tap into before you get to the check valves.
you definitely need to keep boost and vac signal to the fuel pressure regulator, im suggesting you tie it in somewhere else, like to the vacuum block you have at the brake booster (picture 3) so that the front port can be used for pcv.
Sorry this is what I was talking about , and I got off the phone with procharger and they said not to run pcv through my manifold? So let me get this straight
Top foul air line of catch can is in the right spot on the valley port
Bottom will be connected back into the intake port right behind the maf
The regulator line hat goes to the intake ATM for boost reference in the pic will be put where ?
The line on the valve cover port passenger side is going to the inlet side of the turbo
Is this correct ?
the regulator vac signal should be removed from there and joined at the vac block by your brake booster
the rest sounds good.
I have my clave cover fitting e3 going to my turbo
I have the A fitting on the can going to the manifold in line with the maf
I have te valley port going to the other fitting on the can correct ?
5208405386
