Need Expert input on boosted build
Old Oct 15, 2015 | 04:05 PM
ssbandit158's Avatar
Default Need Expert input on boosted build
I have a choice right now to build a supercharged 376 to 427ci motor. I would like to have the 427 as my C6 Z06 came with one originally, however, if it is advantageous to go down in cubes I will do so.
My plan was to order a built ls3 short block from Texas Speed and throw my mast heads on it with about 9.7:1 compression, and add an lsa supercharger as they are pretty cost effective and can put out between 9-12 psi. My horsepower goal is 800whp so I don't think that's unreasonable.
On a side note, I know people are supercharging their Z06's with 11:1 compression with no problem, what is the optimum compression for a built 427 running 10-12psi?
Thanks all in advance.
Old Oct 15, 2015 | 05:42 PM
stevieturbo's Avatar
What blower ?
Surely an LSA would struggle to hit 800 ?
Old Oct 16, 2015 | 08:18 AM
oscs's Avatar
Don't believe everything you read on the internet also it makes zero sense to run the risk of a high compression boosted motor when your goal is only 800whp and you have a 427ci motor.
Old Oct 16, 2015 | 03:21 PM
V-seriesTech's Avatar
Big fan of compression and boost myself.
Old Oct 16, 2015 | 03:44 PM
oscs's Avatar
Its ok, No body actually cares what you think around here
Old Oct 16, 2015 | 03:48 PM
I understand that you want lower compression to prevent detonation, but an article I read says you want to run the highest compression you can but still keep it low enough to prevent detonation. I'm just wondering if there is a way to determine if a boosted 427 with 9.7:1 compression and 12psi is safe from detonation.
Old Oct 16, 2015 | 03:51 PM
oscs's Avatar
VERY safe from detonation on 93 pump gas and a decent tune. You will easily make 800whp with that setup.
Old Oct 16, 2015 | 08:53 PM
I talked to the guys at Texas speed and they said to get 800whp I would need 18-22psi with a 418 at 9.5:1 compression. I'm not saying I don't think that's right, I'm just wondering if that's a rough estimate or if anyone has achieved 800whp on 12psi.
Old Oct 16, 2015 | 08:55 PM
jrpimp00's Avatar
lol, look at my sig (it was with a 4l60e not the th400)
Old Oct 17, 2015 | 02:50 AM
Thanks for the reply, I'm glad to see at least one 800+hp setup with 12 psi. I'm sure there are others, although I don't know if using a turbo or supercharger makes a difference, boost should be boost right?
Old Oct 17, 2015 | 03:56 AM
You arent using an LSA blower which the OP suggests he wants to use though.
Not a chance in hell of the LSA doing that
Old Oct 19, 2015 | 10:46 AM
oscs's Avatar
BTW im talking about using a real S/C or decent turbo not a stock LSA blower
Old Oct 19, 2015 | 04:47 PM
Yeah after looking into it I will be using a better supercharger than an LSA, no point in going through an entire build to put a weak supercharger on it. I just like the roots style blowers.
Old Oct 20, 2015 | 02:26 PM
rkreigh's Avatar
remember another principle, it's total CFM not boost that matters. Boost is just CFM that's stacked up with no where to go.
I learned a long time ago you can go with better flowing heads, better cam, and boost goes down but power goes up and it's less stressful on the engine.
I'm a fan of high boost and low compression as you can turn down the boost but it's hard to turn down the compression +
for 800 a good cent blower will be easier and allow better intercooling than the LSA without a whole lot more $$$
good luck!
