Small mufflers
Old Nov 4, 2015 | 11:14 PM
oscs's Avatar
Default Small mufflers
What are you fender exit guys doing for "mufflers" if you are using them? I saw some spin tech oval mufflers but curious if there is anything cheaper out there.. Or maybe better.
http://www.spintechmufflers.com/muff.../prod_820.html
Old Nov 4, 2015 | 11:23 PM
MY_2K_Z's Avatar
Most setups I've seen don't have a muffler. I'm not going to run one either just straight pipe.
Old Nov 5, 2015 | 07:29 AM
oscs's Avatar
Yeah i know most guys dont run one but there must be a few guys running some small bullet style stuff. Id like to clean up the sound a bit. It likes to pop/crackle out of boost and it drives me nuts.
Old Nov 5, 2015 | 07:45 AM
408GT's Avatar
Vibrant makes some small "mufflers" not sure what size you're looking for, but here's 3": http://www.summitracing.com/parts/vpe-1769/overview/
Old Nov 5, 2015 | 07:50 AM
Rich Halsey's Avatar
7 Second Club
Vibrant makes them up to 5" and in a couple different lengths.
Old Nov 5, 2015 | 08:06 AM
Teddy-2000RS's Avatar
Not sure of your size constraints but i'd look into a bullet style resonator over a muffler. There generally shorter and slimmer, and will get rid of the catless crackle without robbing any sound quality.
Old Nov 5, 2015 | 08:29 AM
ablakez28's Avatar
These. Available in aluminum as well.
Old Nov 5, 2015 | 08:43 AM
squarles67's Avatar
Dynatech makes a cone insert, I think they call it "Vortex".
I plan to run Dynomax bullets
Old Nov 5, 2015 | 09:08 AM
spray280's Avatar
I put Dynamax 24250 behind each turbo. Helped a little but still way too loud for me.
My full exhaust has the Vibrant aluminum mufflers & they sound great.
Old Nov 5, 2015 | 09:15 AM
oscs's Avatar
This is what i meant to say
Old Nov 5, 2015 | 09:17 AM
oscs's Avatar
Perfect. Now if they had these in an oval shape that would be awesome. Any idea if such a piece makes any real difference in sound quality/dB
Old Nov 5, 2015 | 09:19 AM
408GT's Avatar
I put them on a twin turbo setup I had and it made a slight difference in tone but not much quieter.
Old Nov 5, 2015 | 09:23 AM
408GT's Avatar
Actually, these were the ones I used: http://www.summitracing.com/parts/wlk-24250/overview/ They're Dynomax and a little cheaper than the Vibrant ones.
Old Nov 5, 2015 | 09:29 AM
oscs's Avatar
where did you mount them in relation to the turbo? did they help with the crackle?
Old Nov 5, 2015 | 09:52 AM
408GT's Avatar
I had fender exit exhaust right out the side of the fenders behind the front tires. I had the mufflers right behind the fender before it exited out the side. I didn't notice any crackle.
Old Nov 5, 2015 | 10:29 AM
oscs's Avatar
Thanks man
Old Nov 5, 2015 | 11:35 AM
Forcefed86's Avatar
I like the "no neck" style. If I remade my down pipe I'd just use a couple of these inline... I've seen 6" and 8" as well. I can't find them on ebay at the moment.
http://www.ebay.com/itm/300715159916?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Nov 5, 2015 | 08:32 PM
dodgesruck's Avatar
If you want small and cheap look at schoenfeld mufflers. I can't vouch for how they sound as mine is not running yet but they were small( about 6" long), the size I needed and were only about 16-17 bucks a piece. I picked mine up at Day Motorsports because they are local but you should be able to find them online.
Old Nov 6, 2015 | 07:27 AM
oscs's Avatar
Thanks guys
Old Nov 6, 2015 | 10:36 AM
tc3's Avatar
tc3
I used two 3in moroso spiral flows 2 to 3 feet after the turbos and dumped right after the front seats. I know most will say they are a huge restriction but honestly i couldnt notice a difference in spool or power and they reduced volume level drastically.
