Nos to spool up?
Old Nov 15, 2015 | 10:33 PM
Boosted51's Avatar
Default Nos to spool up?
Ive been fiddling with the idea of throwing a relatively small shot of nos 50 to 75 to spool up faster for a while now but just not sure..
-Any of you guys have experience with spray to reduce lag?
-Does it work well enough to justify doing it?
-How much faster does your turbo spool as apposed to no spray?
-How much can you spray before you blow the spark out?
Old Nov 16, 2015 | 06:43 AM
JoeNova's Avatar
Restricted User
Spool up where? Street? Line?
Old Nov 16, 2015 | 02:10 PM
meatheadgn's Avatar
I had a 75 shot with a 408 LS with a 88mm turbo.
It worked great while I had it. It would only come on for a second or so as the boost would come on pretty quick. I had a hobbs switch that shut it off at about 4-5 pounds of boost. From a roll it would work great. I never tried it at the track as I just would use the trans brake to launch it.
I originally put it on for roll racing but then thought it was kind of dumb to roll race the car so I only had it on the car for a few hits and then took it off to save the weight.
Old Nov 16, 2015 | 03:43 PM
Boosted51's Avatar
Street set up. Mostly highway pulls and rolls.
Old Nov 16, 2015 | 03:45 PM
Boosted51's Avatar
Did you notice a big difference in spoil time on nitrous? I'm not too worried about weight so I'm just trying to gauge if it would be beneficial for me to spray a small shot in the lower rpm ranges and taper it off soon as boost starts creeping up
Old Nov 16, 2015 | 03:50 PM
JoeNova's Avatar
Restricted User
If you're on the street, why can't you just downshift? Street racing from 2500 RPM is foolish, and launching on boost/nitrous on the street is even more foolish.
Old Nov 16, 2015 | 04:17 PM
Boosted51's Avatar
I won't be launching on the streets just highway pulls. The boost threshold on 80mm and up turbos on 5.3 is pretty high, I'd like the spool up a little faster with out having to shift and lose a little time. To counter act that I could probably get different gears in the rear maybe 3.27 or lower. I have 3.73s currently. But like I said nothing set in stone yet just trying to weigh out my options...
Old Nov 16, 2015 | 04:38 PM
gsteele's Avatar
What exactly is your current set up?
Old Nov 16, 2015 | 07:43 PM
Boosted51's Avatar
My old set up was a 5.3 with isky triple 12, fast 102 intake with a Borg Warner s480 running stock 80e with a hd2 trans go kit and 3.73's. I'm debating on wether to go with this same set up on my new motor (if I can get it to spool a little faster or if I should go small twins. Like 70mm or something along those lines. Before I was hitting full boost around 4400-4500.
Old Nov 18, 2015 | 02:02 PM
Forcefed86's Avatar
It works great. Get a super tight converter and taller gears to take full advantage of it. Hit it with a 100 shot for 1-2 seconds, then shut it off. It's a night/day difference. Seems like you'd be out of gear fast with 3.73's roll racing? Are you going into OD? what does the converter stall to?
Old Nov 19, 2015 | 10:30 PM
Boosted51's Avatar
Went with 3.73 to try and get a little more rpm to spool up faster but lost a lot of power doing so. Gotta find a happy medium between enough rpm and still keep enough power in it. 3.3-3.5. Or i could just do a twin setup and spool up won't be a problem or add nitrous to the current one.. Many ways i could go about this. Stall was 3200.
