front mount finder exhaust questions??
i want to do this, my question is with the exhaust exiting up front will you smell it inside the car real bad?? im running e85. is there a small muffler that i could put in the down pipe to quit it down some?? a single turbo sounds bad with just a str8 pipe its loud and has alot of rasp... i would like to run 4 inch
thanks john any help will be appreciated
You will smell it. I ran mine dumped for about 3 months before i made my won exhaust. Ran 4" off the turbo to a cutout beside the transmission and 3" from there to a maganaflow.
Lool you don't think you smell it because it is always there. If u could shut the bumper exhaust and then open it again while driving....... You would be like.... Oh there it is
I have a 4in out the front fender. Super quiet, and it does let smell up the car. I guess if you put it far enough forward the exhaust has enough time to disapate before I can get blown in the car if it even does.
Kinda odd all these ppl are getting fumed out. On my 04 gto I had it it as low as possible below the fog light on the driver side. Driving you would never smell it. Sometimes if the wind was blowing right you would catch a wiff at a stop light but never bad at all. I used to get gased out worse with full exhaust going out the back bumper. Prolly because I was running 93 with no cats.
Seems like e85 stinks ur clothes up less either way. 93 really likes to stick around it seems like and just over all smells way nastier.
