Holley EFI vs Factory
Old Nov 30, 2015 | 12:39 PM
  #81
SLOW SEDAN's Avatar
Originally Posted by chub406
Oh ok. That makes sense then, Hatch. Thank you.
Haha. Ya but I'm not baller enough to run 26 psi!
SBE with a billet s480,My set of kill, is your gate spring. lol
Why not? Nothing fancy here, mine is SBE. Figure when it lets me know how much is too much I'll slap another one in it and back it off a quarter turn!
Old Nov 30, 2015 | 07:18 PM
  #82
chub406's Avatar
Im in Iowa. I had to get my 6.0 and 4l80 out of california. They are hard as shot up here. Esp everything is 4 wheel drive. My buddy owns a scrap yard even. Maybe get 1 or 2 ls a year. They are starting to show up a bit more. Or they want a min of 1500 for a long block. Anythong under 100000 they get 2000- 2500 you pull it. I want mine to last a while. If it blows. Ill forge it. Its just a street car! Hahaha
Old Nov 30, 2015 | 09:22 PM
  #83
SLOW SEDAN's Avatar
Ya 6.0's are expensive in comparison. I had a few 6.0's before, once I went 5.3 I wont go back. You can get 5.3's off ebay for under $600 shipped complete intake to oilpan, cant beat it! My 5.3 is going on a year of getting beat on and hasn't complained about it yet.
Old Nov 30, 2015 | 10:27 PM
  #84
chub406's Avatar
I didn't really look on ebay. Thats not to bad esp with shipping. My buddy has 3 5.3s out there but they are no intake, no pan, sitting in the grass getting rained on. lol You see them on craigslist a bunch. The ls's just havint caught on as much up here. The younger guys are getting into them. Speed shops are starting to pop up and will finally tune them. Other than that, ws6 shop is 2.5 hours away and one of the only places that touches them. They pop up on craigslist every once in a while. Most are complete junk. Or theythink its worth a ton of money cause its an LS. At a 700 spot swap meet. 1 guy had a set of 317's. That was it. lol
"That computerized crap" "turbos arent consistant and do nothing but fart and pop" "put a carb on it and be done. barely anything to tune" is the majority attitude around here.
That was the hardest part about the Holley or MS. I could have spent 800 on a csu carb, msd box and been done with it. The msd box is just a bit more than alot of the injectors. Let alone, then I have to spend 2600 on the computer and buy the injectors. lol
That brings a great question since the OP was concerned about money. Why not throw a blow through on it and literally save yourself the cost of the computer?
I didnt because I don't know how to tune a carb. I LOVE the fact of being able to do it through tuning on the laptop. I love technology and this kinda stuff blows my mind on what you can do and see about your motor and turbo.
Old Nov 30, 2015 | 11:02 PM
  #85
93hatch's Avatar
lol at 2600 and buy injectors
Old Nov 30, 2015 | 11:54 PM
  #86
chub406's Avatar
Damit Hatch! Laughing at me everytime I mention a price of something needed with my dominator is not helping! Lol
Old Dec 1, 2015 | 05:47 AM
  #87
SLOW SEDAN's Avatar
Have you thought about a manual controller for the 4L80? Would simplify things and drop entry price a good bit.
Old Dec 2, 2015 | 09:17 AM
  #88
Mekkadon's Avatar
If there is a way to run Holley EFI but also be able to pass OBD II plug emissions, i would be running Holley already....is it easy to swap between the factory pcm and Holley manually for this purpose?
Old Dec 2, 2015 | 09:26 AM
  #89
SLOW SEDAN's Avatar
Originally Posted by Mekkadon
If there is a way to run Holley EFI but also be able to pass OBD II plug emissions, i would be running Holley already.....
People do all kinds of things, really not that hard. Have a stock ECM tied only to the OBD-2 port, flash your VIN, change all codes to "No error reported" and wallah all readiness set and emissions pass.
Old Dec 2, 2015 | 09:30 AM
  #90
69-chvl's Avatar
Wish I knew I could use the stock OE oil pressure sender with the Holley...woulda saved me a 100.00!!! Hell, is there a OE fuel pressure sender too??
Edit - probably could use an oil pressure sensor for fuel too right?
Old Dec 2, 2015 | 10:03 AM
  #91
Project GatTagO's Avatar
Yes, you can use a stock oil pressure sender for fuel. The issue is that the oil pressure senders have huge 16mm threads, while the universal senders have easy to use 1/8" NPT threads.
Andrew
Old Dec 2, 2015 | 06:00 PM
  #92
Mekkadon's Avatar
Ahh ok! I didn't know one could run the stock ECM with just the OBD port hooked up, and I guess let Holley control the rest? I'll do more research on that. Thanks!
Old Dec 2, 2015 | 10:28 PM
  #93
93hatch's Avatar
I bought this for fuel, even plugged right into the holley. Verified with a mechanical gauge and it was accurate.
http://www.ebay.com/itm/271576977896?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jan 26, 2017 | 11:33 PM
  #94
lsdart's Avatar
Thanks for the education folks...
Old Jun 13, 2017 | 10:04 PM
  #95
Monte4ever's Avatar
Good thread right here on Holley EFI stuff. Anything new to report about any added features on the HP version?
Old Jun 14, 2017 | 10:23 AM
  #96
squarles67's Avatar
I've gotten mine running since posting in this thread and I have to say I'm glad I went with the Holley Dominator. My first go at fuel injection and it's fairly straight forward.
A couple things I've learned.
You can use generic pressure sensors. I bought the first ones from Holley but the ones I got from ebay work just as well.
The the ECU connectors are Tyco, while most of the connectors on the engine side are Delphi and you can buy them much cheaper from places like mouser than you can from Holley - here is an explanation of what is what https://forums.holley.com/showthread...als-Holley-EFI
The learn feature is great, especially on initial start. Get it close enough to keep it running and it will be idling in no time.
Last edited by squarles67; Jun 14, 2017 at 11:36 AM. Reason: EDIT connector types per Andrew's post below
Old Jun 14, 2017 | 11:08 AM
  #97
The ECU connectors are Delphi and you can buy them much cheaper from places like mouser than you can from Holley - here is an explanation of what is what https://forums.holley.com/showthread...als-Holley-EFI
To clarify...the ECU connectors are Tyco, while most of the connectors on the engine side are Delphi...
Andrew
Old Jun 14, 2017 | 11:15 AM
  #98
denmah's Avatar
Moderator
i really like my dominator setup with flex fuel and boost control and 80e control and its running the bosch 210 injectors great.
i would give out the tune i am running to anyone on here if interested
67psi of fuel pressure at 26lbs of boost all the way to 150mph only 55% idc on a 10.80 afr on 75% ethanol, the 210s and holley make a great combination for flex fuel setups
Old Jun 14, 2017 | 11:36 AM
  #99
squarles67's Avatar
I'd love to have a copy of your tune
Old Jun 15, 2017 | 10:13 AM
  #100
toytech93's Avatar
Is this the same Global file posted on the Colorado's wiki page ?
