Holley EFI vs Factory
Summit/Holley has the HP ls1/2 kits for $1550.00. That is enough to get an engine running right there - great deal. Add 2 pressure sensors and map sensor if all needed and your still under 2000.00 and can do what most of us need.
Having everything go through one system is amazingly nice though. You can datalog everything you could possibly want to know. You can change everything from shift points,boost,2 step, to what temp the fan comes on, etc... All on one screen.
You will spend way more than you expect! I keep saying it. I am very annoyed how they nickle and dime you. Except its like 100.00 at a time. lol
100 psi sensor that I see Denmah buy for 20.00 is 100 a pop. lol But once its done and over. Its not a big deal. Cant always be about money.
Like the map sensor. I got the holley map and the LS Main Harness. Also bought the ls to map adapter harness from them. Go to plug it in. Its not for their map seonsors. Its for a stock ls3 style. They dont make one for theirs. You have to splice it. lol
The hp is so limited by the amount of I/Os. That sounds legit on the price if going directly through holley.
You seen what I got for 2600. Through holley it was obviously way higher.
check out tickwholesale.com. i checked yesterday. they are still having the holley sale. plus today is black friday. they have half off on membership as well, I believe.
Here is the 24 tooth system:
https://holley.com/products/ls_power.../parts/550-602
The 58 tooth system is the same price.
The Dominator is sold ala carte because it is almost impossible to predict what individuals want to do with the systems. Some want trans control, some want DBW, some run nitrous, some boost, etc...etc...etc...
Andrew
Andrew
Same with the map sensor. Way more expensive than basically every other similar sensor.
I just feel like with the dominator they could have a little more specific harnesses and not rape the people buying the extra parts.
Also the dominator does flex fuel setups but I don't believe it will combine that with boost control to change the tune on the fly.
Again, with as many combinations that are floating around out there, it is hard to predict what people have.
The Dominator does have specific harnesses. There is the power harness (same as HP). There is the main harness (same as HP, Gen III or Gen IV specific). From there you add an injector harness (this is good because there are different styles of injector plugs). The items listed above will get you started and from there you can add various other things as needed (like trans, DBW, etc....).
If you want to make your own harnesses Holley has published all of the connector types that are used on the HP and the Dominator. I can tell you from experience that unless you know exactly what you are doing, building your own can get very expensive.
Andrew
Andrew
Everything I have read about the Holley stuff is that you have to run their sensors. Until you posted that I didn't know that stock ones could be reused which really confused me.
Download the software (it's free) and see for yourself regarding the sensors. There is a Sensor ICF (Individual Configuration File? I forget what it stands for) that allows you to use any sensor you can imagine as long as you know the output curve.
I just get frustrated when people form opinions based on random internet posts from people that have never even seen a product in person.
Andrew
Andrew
I really like the interface of the Holley setup better though. It seems more finished than TunerStudio does.
Keep in mind though that the hp has only 4 inputs and 4 outputs. If you have a fan(s) you will use one of the outputs, maybe 2. Boost control uses another 2 of the outputs so after that your out of outputs. At that point you need to go dominator.
And as for Holley nickle and diming people, I'm in between. I do agree that its horrible, but at the same time people could save a ton of money by not being lazy. I'll tell you right now that I'm the lazy kind and I pay for it. You can make any sensor work, you dont absolutely need theirs, by creating custom tables for sensors. Problem is good luck finding all the offsets, voltages, and all that other stuff you need to create the custom tables. And like someone mentioned before, in their forums they have released where to buy the pigtails, crimps, wires, and all that. But I just buy all of it, aint got time for that.
For the Dominator and the other features like boost control, traction control, etc..Its not the fact of all the things I have to buy ala carte. Its the price of the add ons. Nearly 400.00 for a main harness? Or 100.00 per sensor. When to run their boost control. I need 2 more solenoids and a min of I believe 3 sensors. The accessory plug and wires for 125.00 is way higher than expected. I guess its just I feel the prices are quite a bit higher than I would have expected. That is why when I found the prices on Tick. It changed everything. I saved almost 700.00 by getting it through them, compared to the exact same prices from Holleys website. Then at 75.00 a sensor. I dont feel so bad. haha
I put in my reply on the first page. lol Yes. You can use the stock sensors. Im using the stock oil pressure sensor, coolent, IAT, ect... I got the sensor for my Magnafuel RPR. I wanted to make sure it is dead nuts, so I got the Holley sensor. Thats the only one needed if I wasn't using their boost control.
I got the accessory plug for like 7.00 from the part numbers on their forum. Which is really cool they would allow that. Obviously not buying it through them.
Thats why I'm not so upset with Holley at their prices. If I got off my *** and did it myself. I could have saved prob 500 on the pre made harnesses... but Dam it was nice to lay it out, plug it in. Hit the key. Listen to her talk. haha
Are either of you running Co2?
