turbo size
Old Nov 24, 2015 | 03:05 PM
Seeker1056's Avatar
Default turbo size
I know this question will get the usual too many variables thing but I have to ask
and before I get shot down keep in mind I race a 1600hp cummins diesel making 85 lbs of boost and won the pro-street championship up here in 2014, and I used to run a 341 hp Turbo 2.2l chrysler Lebaron, so I am not a noob to turbocharging to make power
What is the best all around turbo size for twins on the street for best all around performance.
I know some will say small some will say large - but I am talking about lag time to boost and such for smooth power.
For example the wish list on my 67 Beaumont (Canadian Chevelle) with my soon to be twin turbo 6l 4l80e would be for low tens to high nines, and still be very decent on the bottom end for streetability
I have read that power is possible on everything from 58mm all the way up to 76mm turbos
but no one talks about streetability/manners - sure I could bolt on a pair of 78 or so mm turbos to guarantee the power but you most likely would never spool them on the street
the other thing I can not seem to nail down is what is a good stall speed for the convertor to help things along - read lots that a stall convertor is installed but not any stall speeds for street playing
this will be listed as a build in the next couple weeks once I have a shopping list for parts
I just bought the car, have the 6l/4l80e, tires , rims, rear axle 8.8 ford 4:11s - mounts are ordered, corvette manifolds bought, cooling mist meth injection bought, 80# injectors, huge aeromotive fuel pump, etc etc
also looking for reasonably priced BOV and wastegates - but cant find what the perfered sizes are, ie 38mm 44mm 50mm 60mm etc so that would be more useful info
any help here for a baseline recipe for turbo , wastegate and bov sizes would be much appreciated
thanks in advance
Ken
Old Nov 24, 2015 | 03:52 PM
408GT's Avatar
https://ls1tech.com/forums/forced-in...-inside-3.html This 6.0 did well with turbonetics 6165's. I'd talk with Yank about a converter for the 4l80, and probably lose the 4.10's.
Old Nov 25, 2015 | 08:50 AM
SSpeeDEMONSS's Avatar
which truck is yours?
Garrett
Old Nov 25, 2015 | 09:31 AM
JoeNova's Avatar
Restricted User
Twin 62mm turbos with similar sized turbines would work very well on the street.
Go with a fairly small turbo that will still hit your goals. You don't need 2000 HP worth of turbo for high 9s. A single 76mm could get you 9s easily.
