truck intake or ls1 intake ???
Old Dec 24, 2015 | 10:13 PM
jaywill's Avatar
Default truck intake or ls1 intake ???
on a 5.3 with 243 heads w/new valves ,660 BTR springs & full rollers
ls9 heads gaskets
arp head studs
BTR stage 2 cam
80# injectors
dual bosch 044 pumps
7875 turbo
hoping for 650rwhp
Old Dec 24, 2015 | 10:27 PM
bigmandengo's Avatar
Whichever you have or is cheaper/easier.
Old Dec 24, 2015 | 10:35 PM
jaywill's Avatar
i have the truck intake now..but i'm going to need a cowl hood
Old Dec 25, 2015 | 12:37 AM
paulienkeo's Avatar
Old Dec 25, 2015 | 01:08 AM
lmt0705's Avatar
Get a hold of an ls6 intake if you want to get away cheap. There seems to be a negligible difference between that and the much higher dollar ones for the money with boost.
Old Dec 25, 2015 | 01:21 AM
02SSTtop's Avatar
Unless your upgrading to say a fast intake or something like that then stick with the LQ4 intake. especially if it has the 90mm throttle body. You won't find any gains by swaping in an LS1 or an LS6 intake. I have built a lot of 5.3's for other people and the truck intake makes the same power and in some cases more power then the LS6. Now that I am finally building one for myself I will be using the truck intake until I get my magnuson blower. Do what I did and save your money for something that will get you some good return your money like a good tsp cam package.
Old Dec 25, 2015 | 01:27 AM
NemeSS's Avatar
Buying a car intake will be the most economical. No need to buy hood,prep or paint it.
No lq4/lq9 came w 90mm throttle body. They all came with 78mm 3bolt throttle bodies. From the factory.
Old Dec 25, 2015 | 01:34 AM
lmt0705's Avatar
I just figured he didn't want to cut his hood
Old Dec 25, 2015 | 01:46 AM
NemeSS's Avatar
Can find a ls1/ls6/ls2 car intake. The ls1/ls2 and even a ls6 intake would still b cheaper thn a new hood.
Old Dec 25, 2015 | 06:42 AM
forcd ind's Avatar
Stock48 has run low 8's on a truck intake, so they work
If you don't want to cut the hood, LS1 or LS6 intake
LS6 intakes used to be a good value, then folks thought they were made of gold
The LS1's are prob still a good value, if boosted prob not as much diff as opposed to an LS6
Old Dec 26, 2015 | 12:14 AM
jaywill's Avatar
Thanks guys...car intake it is. I don't want to spend money on a hood...the intake is cheaper...the cheapest hood I could find for my 1979 coupe is $549
Old Dec 26, 2015 | 11:01 AM
JoeNova's Avatar
Restricted User
LS6 intakes are as expensive as some of the used aftermarket intakes and perform similar to a truck intake with a little less low-end torque.
If you have $400 to spend on a complete ls6 intake, you might as well look for a used BBK or similar setup.
Old Dec 26, 2015 | 11:19 AM
jaywill's Avatar
i just got a ls1 intake..$200
Old Dec 26, 2015 | 11:31 AM
TXsilverado's Avatar
I dont think a turbo cares what factory intake you use.
Old Dec 26, 2015 | 05:04 PM
jaywill's Avatar
i was thinking the same thing ! lol
Old Dec 27, 2015 | 10:59 PM
02SSTtop's Avatar
I see them all the time in the bone yard with an ls3 ls2 or an ls7 throttle body swap with harness adaptor.. Its a pretty common swap on the 5.3 and 6.0L's. I have few kickin around and will most likely use one on my sonoma build.
