No more needles!
Old Feb 23, 2016 | 01:22 PM
  #81
ljauken's Avatar
Martin,
Do you offer these installed in LS3 rocker arms?
Thanks Lonnie
Old Feb 23, 2016 | 01:48 PM
  #82
badass1000's Avatar
I see you listed you will be coming out with a upgraded bolt package. when will this be?
will these work with the straub trunnion/bushing kit?
ARP Pro Series Rocker Arm Studs 234-7207
Thank you.
Old Feb 23, 2016 | 02:03 PM
  #83
Tuckin15s's Avatar
Damn I just did comp cams kit like 6 months ago I wish I didn't because I want these!
Old Feb 23, 2016 | 03:34 PM
  #84
Martin Smallwood's Avatar
Originally Posted by ljauken
Martin,
Thanks Lonnie
Right now Straub and I are working on this and should be able to supply these already installed soon.
I will let you know when this happens.
Thank you.
The upgraded bolt package is available now I believe.
I'd be glad to get you a kit if needed!
Old Feb 23, 2016 | 09:08 PM
  #85
ljauken's Avatar
Thanks Martin
Lonnie
Old Feb 24, 2016 | 09:10 PM
  #86
Petraszewsky's Avatar
Mine didn't come any stickers
Old Feb 24, 2016 | 09:16 PM
  #87
elephantrider's Avatar
i didn't get one either
Old Feb 25, 2016 | 10:52 AM
  #88
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Sent you an email Martin
Old Feb 25, 2016 | 03:48 PM
  #89
Just replied Dave!
Old Feb 26, 2016 | 01:45 PM
  #90
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
So I saw this reply and I wanted to respond to it.
The needle bearing that encapsulates a rocker arm trunion does not rotate 360* around the trunion during engine operation, and neither does the bushing in my kit. It's not like a needle bearing in a roller lifter that has a wheel. The needle bearing only rotates as far as the rocker is actuated. In this instance for the needle bearing to rotate 360*, the entire rocker would have to also rotate 360* like the wheel of a roller lifter.
So in this same instance no matter needle or bushing, the same needles or the same area of the bushing sees the same load over and over again. In a needle bearing application, only a few out of all those needles see load which means that load is concentrated in a much smaller area than with a bushing which spreads it out over a larger area.
This is where the bushing is superior in terms of handling load and wear. Since the area that the load is being placed upon is greater, the actual load that the part sees is significantly less leading to less wear and tear on moving parts.
Ok, so unless we are talking about a thrust bearing, the load either a bushing or a roller bearing is going to be seeing is what is referred to as a radial load. That load isn't on just a few needles.
Also, unless your needle is the same size as your shaft, they will rotate at different rates.
Here is a video that shows a roller bearing in action. You can see what I mean.
In terms of a bushing vs a roller. A roller from a mechanical perspective is always going to be more efficient. A bushing will increase oil temp based the increase in frictional load. How much may be negligible, but its there.
In terms of a bushing being more efficient or less prone to wear. I don' think that is an accurate statement. As I pointed out in a previous post many mfgs use bushings as they are usually a much lower cost to mfg, and also require less shaft hardness/prep.
The limitations of the LS series rockers are well understood. There are many ways to skin a cat. This is a certainly a solution to the problem, and I suspect that if the material has the proper load characteristics and with proper lubrication it would be problem free for the life of the engine.
Old Feb 26, 2016 | 04:10 PM
  #91
Bearing fundamentals - YouTube
What I was mainly trying to iterate was that you can't compare a roller wheel in a lifter that utilizes needle bearings to a LS rocker that utilizes needle bearings. The roller wheel in a lifter rotates 360* so that the entire set of needles in that bearing will see load throughout their life. With a LS rocker arm that isn't the same because the rocker only moves as far as it is actuated which means it's only rotating a certain amount on the needle bearings and those same bearings will be the only ones that see load throughout their life. I believe that is why people are seeing distinct wear patterns on the trunions that have been posted and only seeing them on a certain area of the trunion.
Looking at your diagram/picture, it is certain that more than a "few" needles as I mentioned are seeing some sort of load. Looking at the bottom few needles in your diagram it looks as if that they're seeing more load than the others surrounding them. This will change as the wheel/bearing rotates. The benefit to a bushing is that concentrated load is spread out over a larger surface area, is it not? Won't individual needles have higher contact areas of pressure and in a more concentrated area? That is at least what I have been led to believe. I was always told by those in the lifter industry that the bushing can handle more load because it is able to spread a more concentrated load out over a larger amount of area. Is this not true in your opinion?
In terms of additional friction that the bushing sees that is most certainly true. I would believe this is why lifter manufacturers have mentioned that bushings can be more picky about which oil is used and how relatively often it is changed to ensure particles in the oil don't make their way to the bushing.
In terms of being more prone to wear when used in the sense of a LS rocker arm, if the bushing can handle more load because it allows the load to see a larger surface area wouldn't it also wear at a decreased rate because of this?
What do you think is causing the wear being shown on the trunions posted?
Old Feb 26, 2016 | 05:25 PM
  #92
dmracing's Avatar
Lots of high end lifters are now using bushing instead of needle bearings. Isky is one example. There intended for high spring pressure and boost.
