Boosted lsx backfiring under boost
Then go to a proper catch can/ evac system. Heck, I've ran just open breathers on stuff.
This is important info guys need to remember to post.
If something like this happens when you make a change don't ignore it.
What ecu are you using, what coils are you using, what plug gap ?
And when you said mixtures are lean when the problem is occurring...as others have said that information is erroneous because of the misfire.
What are AFR readings like immediately prior to any problems, are they normal ?
Thinking about this. OP did you have any breather system when it was tuned?
If not then there's a chance it just might be a good enough change to VE to throw the tables off. How much blow-by you have is going to determine by how much.
!5.22 wouldn't be close.
You can swap it or break out the Air-reg & test the output voltage with key on/engine off. Step up pressure on the reg to see where it maps to. If it hits 105 in the log & stops there's the problem...
If voltage doesn't go up past that point then it's the sensor. If it does then you have to check it at the PCM. It would be odd that it would be a wiring issue if it works to a point & then stops, but who knows.
