Boosted lsx backfiring under boost
Old Jan 8, 2016 | 07:55 PM
  #41
Twinchargedlsx's Avatar
Yes sir.
Old Jan 9, 2016 | 03:47 AM
  #42
stevieturbo's Avatar
Originally Posted by Twinchargedlsx
ECM. And it only reads up to 105kpa when it use to read over 22 psi so I believe that's why it starts backfiring and such
SO it still reads vacuum, just not boost ?
Could the pipe or something be blocked or damaged ? Either that or it is a faulty sensor.
That is clearly the problem and the engine will have been going very lean on load.
And for clarity as some systems seem to use units incorrectly.
key on, engine off what does it read ? It should be around 100kpa, ie atmosperic pressure.
And what does it read at idle ?
Old Jan 9, 2016 | 10:08 AM
  #43
Well like my chip says it's always reading boost. And it stops at 15.2 or so psi and hptuners log reads max of 105kpa. And the logs from the dyno show 200+ kpa but I'll check what it says with engine off and at idle
Old Jan 9, 2016 | 10:13 AM
  #44
Would a log help?
Old Jan 9, 2016 | 11:09 AM
  #45
A log of it running good and before/during the problem would be helpful. Logs will always give useful information and are good to keep records of to refer back to
But if you suspect the map sensor, the two things I asked would be helpful too.
Or via a Mityvac or similar apply pressure to it and test to see if it reads correctly
Old Jan 9, 2016 | 02:10 PM
  #46
Without it running it was showing 89kpa. Pressurized it to 30 psi and it never passed 100kpa
Old Jan 9, 2016 | 02:25 PM
  #47
gtfoxy's Avatar
Did you check input & output voltage at the sensor?
Old Jan 9, 2016 | 04:09 PM
  #48
Well I broke the sensor on accident but the inside was like black
Old Jan 9, 2016 | 04:11 PM
  #49
I ordered a new sensor since this one looked not so good on the inside
Old Jan 9, 2016 | 04:14 PM
  #50
Either the sensor is fucked, your pipe for testing wasnt actually connected ( unlikely but had to say it ) or there is a wiring issue from ecu to sensor.
The sensor has 3 wires. Ground, signal and 5v supply
When the sensor is connected you will see a voltage at the 5v pin obviously, also at the signal wire and obviously not at the ground,
If you can identify 5v and signal and short these out, that will at least confirm your ecu is able to see the voltage and you should then see a high pressure value at the ecu
Unplugging the sensor should also cause a change in reading at the ecu.
Old Jan 9, 2016 | 04:19 PM
  #51
Well it's screwed now anyway lol
Old Jan 9, 2016 | 06:10 PM
  #52
I got voltage on all three pins.. Could that mean bad ground?
Old Jan 9, 2016 | 06:14 PM
  #53
Testing how ? It should be impossible
Sensor ground is wired only to the ecu/sensors. It should never connect to chassis ground.
If you get the meter and stick the black onto battery ground then probe red to each pin in turn ( DC voltage ) you should only see a voltage on 2 of the pins
The pin with no voltage will be the sensor ground
Or you can identify with meter red wire onto battery 12v and probe each pin with the black probe.
Few videos on youtube explain it well too. Not sure why he's identifying the 12v supply as VSS, just use the live battery terminal.
Old Jan 9, 2016 | 06:17 PM
  #54
Hmm well I defiantly had voltage on all 3 wires... I had a ground issue last year for ignition could that caused misfires in the mid rpm range
Old Jan 9, 2016 | 06:44 PM
  #55
If you unplug the sensor and test at the wiring connector from the ecu, how does it fair ?
ie you are now testing the wiring for the most part, ignoring the sensor
From battery ground to each pin in turn, DC volts
Ground should read zero
Signal pin will probably read a voltage, can vary though but it wont be a full 5v and it wont be 0v
5v pin should read 5v exactly ( or maybe like 4.999 )
If there is a wiring issue or other fault interfering with sensor ground it will be screwing up more than just the map sensor readings at the ecu, it could skew lots of readings from various sensors.
Although at minute prob easiest just to stick another sensor in lol
Old Jan 9, 2016 | 06:56 PM
  #56
Shoaf85's Avatar
I had a MAP sensor wiring pin to the PCM go bad some how. I could wiggle the wire harness and the ground wire would start seeing voltage. Was causing the map sensor to see 150+ KPA at idle, which in turn caused a seriously rich condition. Different scenario but sounds like your voltage problem on the map sensor could very well be your issue. Now for your sake I just really hope that the engine wasn't hurt. If the engine was seeing 10+psi but the map sensor was only reporting/commanding fuel for a 0 boost/vacuum air flow that would explain your lean AFR readings.
If you are having grounding issues then this could have affected some of the other 5v sensors as well. Like crank and cam sensor which could be causing the misfire problems.
Good luck with it and on a side note what do you think of the B15 engine so far? I have really been considering one for my car. You can PM me so not to clutter up this thread.
Old Jan 9, 2016 | 07:11 PM
  #57
Well I have had a crank shaft sensor code come up so I'll be going through grounds tomorrow it looks like and testing the harness haha and well I think it's a minor issue cause the engine runs fine until 10psi and my a/f hasn't been in dangerous spots so that's good. And the b15 so far is really better then any machine shop or anything. It's making 739hp through a 4wd truck chassis and I have 35 inch tires and I'm on 91 pump gas and water/meth. And it has a 2 year 50,000 mile warranty. And I've abused it a lot already haha it's been a solid engine. It's nice for drive ability and gets good mileage. I was getting 18mpg in a 2500hd truck so I mean in a car it'll be a lot better obviously
Old Jan 9, 2016 | 07:18 PM
  #58
I got a 4.9 and a 3.8 and then a 27.2 voltage...
Old Jan 9, 2016 | 08:02 PM
  #59
MY_2K_Z's Avatar
I have a hard time believing 18mpg having owned 2 2500hds and all my friends also drive 2500hds and we all get between 8-12 period. With trailer, without trailer, downhill doesn't matter but the b15 gets 18 hmm....
Old Jan 10, 2016 | 05:05 AM
  #60
Again dont confuse sensor grounds with power grounds.
Ultimately yes they do all go back to battery/chassis ground.
But sensor grounds run only from the ecu to any of the sensors. At no point ever beyond the ecu will they or should they pair with chassis ground
So if you unplug the ecu and test for continuity between the sensor ground wiring and chassis ground, it should be open circuit.
But it could be a wiring issue, but as described the map sensor is very easy to test as is wiring to the ecu via methods I stated.
