Boosted lsx backfiring under boost
Coils have one main power ground which needs to be good and ideally grounded local to the coils.
The other wire sometimes called a ground and can be grounded in aftermarket ecu installs is actually a misfire detection feedback wire, but technically it is not a ground.
Other two are 12v and ecu trigger to charge/fire the coil.
#1 you said this was a new engine with 50K mile warranty.
Have you had this issue from the beginning?
#2 you also stated your grounds are white.
Is this like a corrosion white? (Powdery substance)
Joe
