turbo hot side coating
Old Feb 1, 2016 | 10:29 AM
Jwooky's Avatar
Default turbo hot side coating
Anyone have any success with coating the hot side of the turbo?
Cant stand the thought of them getting rusty as I have seen many have.
I have heard of brush on ceramic coating being applied to headers.
Old Feb 1, 2016 | 10:39 AM
forcd ind's Avatar
I had the Eastwood stuff hold up pretty good, but the pipes need to be prepped-it held up well on the turbo
Old Feb 1, 2016 | 11:56 AM
Ping King's Avatar
I used Satin Black and bake it in a homemade oven. Works great.
Old Feb 1, 2016 | 01:27 PM
tta656's Avatar
swaintech lot of GN guys used them for their 9sec v6 motors.
Old Feb 1, 2016 | 01:36 PM
FrossB's Avatar
I scuffed, cleaned and sprayed mine with bbq paint haha
if it bubbles or chips ill just cover it with a turbo blanket
Old Feb 1, 2016 | 02:40 PM
Jwooky's Avatar
This one?
http://www.eastwood.com/silver-high-...html?reltype=3
Old Feb 1, 2016 | 02:54 PM
forcd ind's Avatar
That's the one, only I used black-I thin it with laq thinner and spray it
Old Feb 1, 2016 | 02:57 PM
Jwooky's Avatar
Ok thx, how long have you had it on?
Old Feb 1, 2016 | 04:27 PM
panic's Avatar
Tech Line makes some good stuff.
All hot parts should be reflective (chrome = good) and light-colored (silver, white, aluminum) to retain that heat energy, and reduce under-hood temps.
Black = worst.
Old Feb 1, 2016 | 07:22 PM
Jwooky's Avatar
Anyone use Cerakote?
Old Feb 1, 2016 | 09:00 PM
MY_2K_Z's Avatar
I used cerakote on mine. No results yet but as a person in the coatings industry I can say it sprayed very well and leaves a very nice hard and durable finish. I've banged it around and even took my map gas torch to it and no blistering or anything. I also wrapped it to help hold the heat in even more. Name:  D2BAF9EE-0593-4E87-8DCA-C08226002268_zpsxlhmn6ef.jpg
Old Feb 1, 2016 | 09:24 PM
rpturbo's Avatar
Is the cerakote stuff, the stuff you have to be "in the industry" to buy it? I can't remember which one I looked at, but read great reviews on it, contacted them, only to be told, I had to be a powder coater company to buy it. I thought about banging out a small llc just to buy their crap, but sounded like a little too much work.
Old Feb 1, 2016 | 10:53 PM
MY_2K_Z's Avatar
Anyone can buy cerakote. And FYI a pint will do all your hotside and then some.
Old Feb 2, 2016 | 07:25 AM
Jwooky's Avatar
would 4 oz do two housings?
Old Feb 2, 2016 | 01:54 PM
Forcefed86's Avatar
I’m not sure whats in the rustoleum BBQ grill paint but it plain works. I’ve used several spray on coatings like VHT and none of them hold up like the BBQ grill paint. It greys a bit, but keeps the metal coated and free of rust. I literally ran my turbo buick manifolds 6+ years on the stuff and never had any finish issues. I use it on all my turbo hotsides as well. They have flat black and ultra which is more of a satin finish. I usually spray and then wrap my mild steel hotsides. Then spray it again.
Old Feb 2, 2016 | 02:59 PM
Jwooky's Avatar
^^wow, very surprising.
Old Feb 2, 2016 | 03:41 PM
MY_2K_Z's Avatar
Yes. Only need to apply two medium light coats.
Old Feb 2, 2016 | 06:34 PM
Krom's Avatar
If you want and actual thermal coating, go with swain tech
http://swaintech.com/race-coatings/r...aust-coatings/
Like all of Swain Tech’s coatings, White Lightning™ is a performance improving coating. What makes White Lightning™ the best performance exhaust coating?
White Lightning™ really is ceramic so the material is a superior insulating material.
White Lightning is applied much thicker than any of the cosmetic coatings. White Lightning™ is applied about .015” thick compared to about .002” thick for the cosmetic coatings. Because White Lightning™ is the best insulating material and it is applied thicker than any other coating, White Lightning™ offers performance improvements that cannot be matched.
Many companies apply the shiny or colored paint based coatings and call them ceramic. Those thin shiny coatings are very different than Swain Tech’s White Lightning™.
Whereas it would be more accurate to call those thin shiny coatings good high temperature paints that may have a very small amount added to them, Swain really uses a ceramic coating that is applied molten where it bonds and cools directly on the substrate.
Old Feb 2, 2016 | 06:58 PM
FrossB's Avatar
I do exactly this as well!
Old Feb 2, 2016 | 07:14 PM
Forcefed86's Avatar
Using SS safety wire to secure the heat wrap also works really well compared to those SS zip tie thingys. (I hate those!)
Also spray it directly on the turbo housing and it does not peel or flake.
This is after a year of hard use... E85 exhaust spits out a ton of moisture. Rusted the crap out of the inside of the housing... outside is just fine.
