Which stall to get .........
Old Feb 6, 2016 | 05:20 PM
11SECSS's Avatar
Default Which stall to get .........
I'm in the market for a new stall and was wondering what you guys are running. My setup is a procharger making 10# and rwhp is only 550 ish going thru a 4l60e car weights around 3400 w/me. Was running a SS4000 but was thinking of going with a 3600-3800 . Been looking at FTI / Circle D / PTC and Yabnk again.
Old Feb 7, 2016 | 12:52 AM
Blown06's Avatar
8 Second Truck Club
Why are you looking to change?
What does it flash to?
Shift rpm and fall back rpm?
Slip % at the top of high gear?
Have you ever had the thing on a dyno to at least get an idea of where the motor makes power? If not, do you have access to your V/E table? If so, overlay a run and tell us at what rpm you have the highest V/E number. That will give an idea of peak torque.
Old Feb 7, 2016 | 11:08 AM
11SECSS's Avatar
I'm waiting on tax money so I can buy HP tuners so I can data log ,since my tuners and friends not at track to use theirs.
Just wanting something a little tighter , never had any problems with it when I was N/A but once the procharger was added just not the same had issues hit rev limiter on shifts and before end of 1/4 . I had the trans freshened up over the winter and nothing bad was found inside just normal wear and tear . Might just try a YANK SS3600 this time if not I can send it back for a free restall as I I"ve allways used Yank stalls .
Old Feb 7, 2016 | 01:39 PM
panic's Avatar
What RPM brings you to boost?
If your chassis works, your stall should reach that.
Old Feb 8, 2016 | 12:42 AM
Blown06's Avatar
8 Second Truck Club
You mention the issue of hitting the rev limiter before the end of the track. What tire/gear/rev limits do you have? I assume you are in a 1:1 high gear at the finish line???
Old Feb 8, 2016 | 07:20 PM
11SECSS's Avatar
Rev limiter set at 7k, 3.42's, 315/35/17
Went ahead and ordered a new Circle D stall so hopefully first week in march I'll get a chance to try it out.
Old Feb 10, 2016 | 08:54 PM
rpturbo's Avatar
So what made you change to Circle D? What size stall did you order?
Old Feb 11, 2016 | 02:37 PM
Circle-D_Brian's Avatar
We went with the 245mm diameter similar to the ss4000, but opted for a slightly tighter pump and stator combination. We agreed that without changing rear gear or tires, this would be necessary. We wound up with our 4C 38-4000 stall speed. This should allow appropriate RPM drop on the shifts, without sacrificing much if any 60'.
-Brian
Old Feb 11, 2016 | 03:33 PM
11SECSS's Avatar
I'm pretty sure my 60 ft will improve with the tighter converter as I'll probably leave a little harder now with the newer trans with all the other upgraded parts and stall combo. Cant wait.
