Ethanol Content and actual results
Just a thought.
I'm new to the alcohol fuels so this all will be a experiment.
And does E85 always come out at 85% or close ?
A recent post elsewhere had a guy using VP E85...and via his flex fuel sensor this registered only 65%
Confused he got some more drums to test...and same result, all in the 61-65% range
Here the better pump fuel registers around 7%, cheaper pump 4-5%
He then got some Sunoco E85, it came out at 81%
Now obviously flex fuel sensors can be led astray ( usually by moisture )...but this one sounds like a strange result, especially when it was all new drums of fuel tested.
Any comments ?
I’d get a simple test vial like pictured below and check the fuel straight from the barrel. Can get them cheap at Sears.
http://www.searspartsdirect.com/part...FQIKaQodzycBtA
Dont even see anything listed on ebay within Europe for such a thing, all listings are in the US.
Will show him it anyway, as something needs tested !
And as E85 is non existent here....they wouldnt even know what a flex fuel sensor was if you shoved if up their hole ! ( not that it is a good way to identify one lol )
Most of the guys in the UK using E85, are buying the race versions from the big brand names, because there is no pump E85 anywhere.
Even still, sensor or not, it should be reading a lot more consistent than it seems to be !
Trying to be cautious with this mutt of an engine I slapped together after my AES screwing. Summit aluminum block, 24x crank, LY6 rods/pistons and 317s.
