MS3-Pro Engine Management System.......anyone use it...?
can you see this image?
this works if you have the MS3, racepak, and TCU, it asks the TCU for the VSS info over that POLLING option screen, and then the VSS1 settings grab it itno the MS3, then it broadcasts it back out over the dash Canbus.
works on gold box and old MS3x setup, tested on cameron vic's car also
Originally Posted by Jax326
Does anyone know if the ms3 pro is capable of controlling 16 injectors? I see it says "up to 12 sequential" but I need 2 sets of 8 for dual fuel setup. 8 small injectors for cruising on pump gas and 8 larger injectors for alcohol when in boost.
Denmah, have you ever tried using an android based tablet as a dash interface? I read that this can be done? Any info on this? I have a Galaxy tablet that fits perfectly in my car I would like to use, and also save on cost for the racepack for now. Thanks!
I have a microsquirt using a tablet for gauges and it works great. I am using a Bluetooth for connection and the only problem I have is when reconnecting with the laptop after using the tablet I have to remove the device and reinstall the device in Bluetooth connections to get communications
Denmah I tried your setting still didn't work! Im so frustrated! I know its just a speedo but dam I just don't get the reason why. Think I could send you my tune see if im missing something. I wonder if its different because mines a iq3S with built in can wires. Your using the can adapter.
I know this is an older post but I had the same question if I should get the MS3Pro or something different for my 74 corvette 5.3 swap and for what it's worth I recently received my package from DIYAutotune and I bought the pro plug n play harness, wideband o2 and few other things and I have to say I was blown away by the quality, neatness, and design of everything plus the customer service was great. Oh and I had a hat and shirt in the box to when I opened it. Working on the install once we get the engine set where we want it. I will be posting pictures of it as I go. Thanks Alex
I have two MS3pros and a third lying here useless. It went dead one day and would not turn on. I enquired with DIY as to what I could do but they told me they didnt do repairs. Its brand new and useless. The two that work are fine. Great expandability. I use tci tcu's. Would that be compatible with the racepak ms3 combo?
I think that qualifies! Have to use what we have right?! What kind of vehicle do you have your MS3Pro in? And that's weird they wouldn't help you with your dead ms3, I have had extremely good customer service so far.
