Driving impression with a smaller AR
Old Feb 18, 2016 | 02:34 PM
forcd ind's Avatar
Default Driving impression with a smaller AR
Weather has been crappy, but I wanted to take the car out for a test drive and see how everything was, since it went thru a bunch of changes.
I had a 92 MM turbine with a 1.25 AR-I wanted a little earlier spool, so I replaced the turbine with a 1.00 AR-it def made a diff, spools quicker
So do my rear tires, lol
I'll have to dial back my boost controller until I get some good data logs on it, see where I am at now
Old Feb 18, 2016 | 08:27 PM
69-chvl's Avatar
Jim would you say it's a big or subtle difference?
Old Feb 19, 2016 | 01:55 AM
RonSSNova's Avatar
Very cool!
Good info.
Ron
Old Feb 19, 2016 | 05:55 AM
forcd ind's Avatar
For mine it was a fairly good diff, I used to see boost starting around 3500 RPM's, yesterday with a quick blip I saw around 3 lbs before 3500
If I had an 83 MM turbine it would prob have been better, but this is what I have to work with
If warm dry weather comes around I will do more testing and datalogging.
The driveway over to the garage usually gets in bad shape with the freezing, thaw, mud comes to the surface-when I hit the lottery I will have it paved
Old Feb 19, 2016 | 06:06 AM
saleh660's Avatar
Is't 5.3 or 6.0 ?? auto or stick ? I am going to swap my 5.3 with gt45 soon .
I am building lq4 and looking for s475 but Am not sure which turbine to go with ? I am leaning toward 83 1.00 A/R as my truck is heavy and got manual trans ( daily use ).
Old Feb 19, 2016 | 07:12 AM
69-chvl's Avatar
That's much better than my s475/83mm/t4 1.10 does...I don't see positive pressure until 3400 or so. This is just rolling onto the throttle from a steady cruise.
Old Feb 19, 2016 | 08:38 AM
LJMSJohn's Avatar
if you have an 83mm S475 and don't see PMP until 3400.... you need to work on your tune.
Old Feb 19, 2016 | 09:01 AM
forcd ind's Avatar
6.0, turbo 400, 317 heads, LJMS flat top pistons, JFR 218 cam
T4
I am over 3900 lbs
Old Feb 19, 2016 | 09:14 AM
69-chvl's Avatar
Give me some suggestions...I run full timing (27*) and 13:1 AFR till about 5-6psi.
Old Feb 22, 2016 | 02:29 PM
LJMSJohn's Avatar
whats the hotside setup?
Old Feb 22, 2016 | 04:12 PM
GMCtrk's Avatar
went from the 75/83 to 80/96....laaaaaazzzy, but pulls like a monster on the big end. the 75/83 was more fun on the street but felt like a sunday drive going down the big end of the track.
Old Feb 22, 2016 | 04:42 PM
69-chvl's Avatar
Truck mani's, 2.125 hot, divided all the way to the turbo.
LOL always appreciate the input GMC!!! At what point was the 75/83 tapped-out in your case...ever document that?
I really cant complain...any more power down low at it would just burn the tires worse. Going to try and get this dam boost control rigged-up.
Old Feb 22, 2016 | 06:24 PM
GMCtrk's Avatar
I was able to go 10.82 at 130 @ 5045 lbs (per RPRs scale) with the 75/83 maxed out.
I haven't been able to push the S480 much before this happened:
Old Feb 22, 2016 | 06:43 PM
3 window's Avatar
What size exhaust on the truck with the 75/83? All the way out the back?
Old Feb 22, 2016 | 06:46 PM
69-chvl's Avatar
What psi what that at?
Old Feb 22, 2016 | 06:51 PM
GMCtrk's Avatar
4" from the turbine to the rear bumper.
My new setup has a cutout right at the level of the trans bellhousing but I haven't opened it up at the track yet. I'm seeing 20-21 psi on the heavy JGS spring. Should pick up a ton of power with it open but don't know how much more the old 2002 SBE can handle.
16 psi in 1st, 17 in 2nd, and 18 in 3rd with the converter locking at 100 mph. Locking the converter picked up almost 2 tenths and 3 mph.
Old Feb 22, 2016 | 07:01 PM
3 window's Avatar
Any muffler or no? I've got 4" on my Nova all the way back with a straight through Hooker max flo. Same 75/83 turbo also.
Old Feb 22, 2016 | 07:10 PM
GMCtrk's Avatar
It's a Diamond eye duramax exhaust with a 30" Magnaflow round diesel muffler welded in. It's extremely tame. Coupled with the 212 cam, you'd never think it had more than 350 hp. lol.
Old Feb 23, 2016 | 08:24 AM
gtfoxy's Avatar
GMC, what AR is your turbine housing?
Old Feb 23, 2016 | 12:18 PM
GMCtrk's Avatar
the t4 was 1.0 AR
