Weird stuttering and lean condition at low boost.
It also started doing a stuttering when you could hear the turbo start spooling but not necessarily in boost. I then noticed my LED for my Methanol kit was not coming on either. I went home and started looking over the car and checked all of my wires going to Methanol kit and couldn't find anything and then tested the kit with the controller and it sprayed fine.
Then I took the car back out and tested it again and this time everything was fine. Hit 18 pounds and my LED went green. So the question I have is what the hell happened? I didn't fix anything and it started working fine. I am a little confused and a little concerned.
This is a 408 with a BW S476 and an Alky Control kit.
Thanks
If you have no way to purge you may have had air in the lines. It then would take a little longer for the meth to come out initially and clear up after you used it once.
