How Reliable is Your Turbo Setup?
Obviously look at SloppyMechanics builds as well.
So far, I've
- Changed the oil
- Tightened exhaust manifold bolts
- Had my 4L80E rebuilt since it was an abused junkyard unit and 2nd gear failed.
That's it. This thing is stupid fast on 16psi and idles at 650rpm. I couldn't be happier with the power and reliability.
My Cutlass had a 150k+ junkyard motor on it, I was running all ebay turbo parts and made my turbo log out of sewer pipe. The car made over 600HP, I drove it like I stole it, and I would not have hesitated to drive it anywhere I wanted.
I was running a single GSL392 (inline 255) fuel pump with no indication of running out of fuel. I was told that people push the 255 to 650 WHP no problem.
I think that you will find there is a big difference between the LSX platform and a neon or SBF, but in either case the foundation is a good tune.
i ended up hitting a wall with the truck so i threw it away and put the motor with a new twin turbo kit in a full size and now im driving that around. It does fine and i can drive it anywhere. it was my only car for the few months i had to rebuild my blown up evo. the 4.8 has been together and running in my possession for about 3 years now, always boosted. It started as an iron block junkyard 100k+ motor, i took all the guts out and put them in a used L33 block, i reused everything, bearings, gaskets, bolts, even the head gaskets, and the motor is still unopened from that. I did zero machine work and minimal prep and cleaning. i did put ebay head studs in and good valve springs.
my opinion is its all gonna be how you build it/who works on it. guys like denmah have the skills to make a zero dollar build reliable. Ive met some people that can throw 100k at something and its still an unreliable turd.
It isnt rocket science.
Any problems are usually bad install, bad tuning...bad person doing it, at least certainly at the sort of level you're talking about.
Of course how well it can all be done...then comes down to your budget.
You can for sure make it reliable at that power level. But to make it reliable, you need to be able to handle the reality that you will be spending quite a bit. If reliability is more important to you than cost, then its only a matter of picking a forged setup with a appropriate sized turbo, fuel system, supporting mods, and tune.
Many go with a 5.3 and add a turbo because it is cheap. It can be made somewhat reliable, but the reality is that your still on borrowed time and eventually it will not last, but another 5.3 can be found for about $700-$800 a lot of places.
If you want it to last, build the motor, get the correct supporting mods, and a good tune. Should last a VERY long time reliably at 600 to the wheels. It won't be cheap though, but so far you have not voiced your concern on cost. That's what stops many from going reliable.
here are some of the headaches and what to expect.
1. car was built and worked very well with no issues for first 2 years
2. ttix manifold rear mounting flange cracked and had to be replaced (ttix was great, price was 600 for the manifold). tough job as no clearance but can be performed with basic hand tools.
3. AC failed, a big issue with the ttix and C5 to replace the compressor
4. went from stick to auto to beef up the drivetrainn and go from 3.9 gears to 3.42 (great mod!)
5. car would run hot with AC on in hot weather above 95 deg. Went to dewitts dual fans to replace the stocker and B&M tranny cooler and the car works fine in the heat. even with the big after market dewitts radiator stop and go traffic was too much for the factory fans to pull through the much thicker cooling stack with intercooler, and front mount tranny cooler (want to move that one to the side pods in front, but clearance is tight with the ttix).
6. this car is a tiger shark with the stinger hood so it does get a bit better airflow to the intercooler and rad, the turbo cars crank MUCHO heat when stuck in traffic with the AC on.
overall, the turbo kit has been great and I'm not afraid to crooze relaibly at 600 or turn it up for 800 *drag radials needed!!*
turbos get a bad rap for reliability. just ask a trucker!! don't see to many of them without one and they do pretty well.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
What pumps ?
And as always, how hot is your fuel getting ?
I can easily drive for around 4 hours ( ie until tank runs out ) with my 044's, never any problems.
If fuel temp actually is an issue, just add a fuel cooler.
I am running dual Walboro 340s.
